Question about GE Advantium 120 Convection/Microwave Oven
Arcing My Advantium 120 Microwave is achhing below the glass on the turntable.
  • Linda Long Nov 19, 2008
    mine does this also. but only with popcorn bags.
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
Posted on Dec 12, 2008
  • picof Sep 24, 2013
    did you replace the central shaft and the turntable or just the turntable? and does your turntable get hot when microwaving on empty?
Turntable does not turn
checkunder neath it is belt driven and probably has broken belt
Mar 18, 2015 | GE Advantium 120 Convection/Microwave Oven
Advantium arc
Unfortunately there is nothing you can do but to buy a new microwave oven Once it arcs it causes burns on and in the parts and most times cleaning does nothing
Sorry, good luck
Jan 24, 2014 | GE Advantium 120 Convection/Microwave Oven
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
I'm experiencing occasional arching from the center of the oven i.e. out of the spindle that rotates the metal rack and glass turntable. I cleaned thoroughly and it seems to have minimized the proble
Its unlikely to be associated with the tuntable motor. Units are tuned to prevent arching. Therefore it appears something may have changed inside the unit. Be sure there are no loose items or bits of foil or other mateallic items inside. Also check metal turntable.
Dec 31, 2011 | GE Advantium 120 Convection/Microwave Oven
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
Sep 26, 2011 | GE Advantium 120 Convection/Microwave Oven
How do I clean the oven in the Advantium 120
We have the same oven and we use glass cleaner and soft scrub cleanser. If the glass on the top of the oven (where the cooking light is located) is really dirty from splatter, you can use a razor blade scrapper. This is the same type of scraper you would use to clean paint of a window. Our Advantium actually came with a scraper from the factory.
Nov 28, 2010 | GE Advantium 120 Convection/Microwave Oven
My advantium lights, turntable turns, timer works, appears to be working as usual, but does not heat..
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Nov 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Sensor error and periodic beeping for Advantium 120
If the internal cooling fan does not come on when you're microwaving, the magnetron will overheat and the thermal cutout will be tripped, causing the oven to go dead until it cools back down.
If this happens more than a few times, the magnetron can be damaged.
If the turntable is not turning (assuming it's not set to be off) when you're microwaving, then the problem lies on the relay circuit board (sub PC).
If the turntable is wokring and the fan is not, then the fan motor or wiring is at fault.
At this point, with such odd problems, I recommend that you contact GE customer service for your nearest GE-authorized service center
GE Customer Service is here.
Good luck.
Jan 10, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
551 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
