Question about Toshiba 27A44 27" TV
No remote for toshiba 2552db tv
Asi have saidi do not have the remote,but can i still toggle between the av modes to use the playstation on it?
i can get the av on the screen using the menu button but cannot change it...thanks
5 Suggested Answers
jeandesir
  • 25 Answers
SOURCE: how do i switch to my av mode without a remote
try going to channel 00, or look for the "aux" or "input" button on the tv. if anything you can get a universal remote control.
Posted on Sep 15, 2008
get-it-goin
  • 85 Answers
SOURCE: Remote and TV/AV Button
if you take the remote control apart,look for any signs of spillage ingress.very common,especially if you have kids.thoroghly wash the large area with the black tracks,the rubber keypad too,and dry all gently with a hairdrier for twenty mins or so.fixed.other common problems may inlude a broken lead on the yellow or blue resonator,or on the infra red transmitter diode,.its top centre of the board.failing this try grandata,based in wembley,middesex.they are online.hope any or some of this helps,regards,steve.
Posted on Nov 05, 2008
  • 9 Answers
SOURCE: FIND AV BUTTON
You can try turning on the video game and changing that tv stations as low as they'll go. sometimes the station will go from 3, 2, aux, side video, av1, av2, etc.. Hopoe the info helps GOD Bless You
Posted on Mar 21, 2009
a1electronic
  • 30 Answers
SOURCE: Toshiba 27a45
yes a universal remote will work but you may need to try several to find one that will, not all work to select your inputs. first try changeing the channel below channel 2, thats were most tv inputs are located (accessed)..
Posted on Jul 20, 2009
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
Can not change my toshiba remote back to dish mode how do i do it?
The TV have been changed to program 12. Press the TV/AV button to come back to AV.
Jul 13, 2014 | Toshiba 26HF84 26" TV
Go to av mode without remote in toshiba 27d46 tv
Here is a manual for that tv. Page 27 says to push the tv/video button but that is on the remote. Do you have a tv/video button on the tv itself? If so, push it until it cycles through to the video input you want
http://www.manualowl.com/m/Toshiba/27D46/Manual/33233
Jul 28, 2012 | Toshiba 27D46 27" TV
Toshiba 32a35 no remote
Hello
Since there is no "Menu" button at the front panel of your TV, you can't change its mode to AV or back to TV. Just try to buy a universal remote control, which has setup codes for Toshiba TV. You can find this at the code list of the remote control. Or buy an original one from the authorised service center for Toshiba at your town.
Feb 26, 2012 | Toshiba 32A35 32" TV
I cant find the av button on my tosiba tv. i have got a wee and it wont work any ideas please e/mail me at wchelseablue@blueyonder.co.uk thanks, johnny
there should be an input button somewhere on the remote. if you dont have the remote, some tv models will toggle through the av inputs at the bottom on the channel numbers. try channel down till to ge to zero then hopefully you will see av. if not you will need to go to the remote. if you dont have remote, you will need to go buy a universal remote.
Dec 24, 2010 | Toshiba Televison & Video
Weve got a toshiba tv model 289s4A & want to plug our ps2 into it, cant find how go get the av channel on the tv. We have connected the av cables but when you change channels on the tv, theres no...
If you have the remote, look for the source button. It should allow you to toggle the settings.
Otherwise they are usually after channel 2 as in Hdmi, Av1, AV2 etc..
Good luck
Dec 09, 2010 | Toshiba Televison & Video
How do I change the TV from video mode to TV mode without the remote control?
Look for a button named AV or Input or something of the like. Press the button to toggle between different video modes such as AV, TV, S-Video etc.,
Dec 03, 2009 | Sanyo DS31520 31" TV
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
How do i switch to my av mode without a remote
Sep 15, 2008 | Sanyo DS13204 TV
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
Dec 26, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 27A44 27" TV Logo
224 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
