Back to:
Tags:
Sharp AL-1655CS Laser Printer
Printer Tray
posted by senorricardo on Nov 27, 2006
I would like to select tray 2 as my default printer tray.
How do I do this?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 10, 2007
Not Rated (0)
HenryJohn
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Go into the Printer Dialog box from the start button. Right click on the printer and select Properties. Select Printing Preferences. Select the tab for 'Paper'. In the upper right hand corner you can select the paper source, just select tray 2 as the default and save your changes.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Printer Tray:
I don't want to Accept this solution
Can you Help with these Printers problems?
I just put a new toner and drum unit in machine. It now...
Hi - I'm trying to print a double sided page but the back...
my numbers/letters are getting a shadow image almost 3...
my letters/numbers are getting a shadow so they look...
en el rspf mando a imprimir pero solo avanza unas 3...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
