Question about LG WM-2277HW Front Load Washer
LG WM-2277HB washer does not drain and make rattling noise.
Our 4 yr old LG WM-2277HW does not drain and makes a rattling noise (bottom left) during the drain cycle. It shows error code 0E ( or DE). We drained water ( through the horse bottom left) and cleaned the filter. it still makes a rattling nose during the drain cycle.
I am guessing either the drain motor is broken or some junk ( coin, pebble, etc) is stuck in the Drain motor. I am trying to check the drain motor if I can remove the junk. I am looking for information on how to remove junk from the drain motor and how to get to it. Am I on the right track?
  • yunet Nov 17, 2008
    Thank you for the information.
    Is it possible that foreign obects (i.e, coins, rocks, etc) can cause the rattling sound and not drain?
  • 1,543 Answers
You will need to replace the drain pump motor. The pump impeller has separated from the motor shaft. You can push it back on, but it will just come off again. I have not tried adding adhesive because I didn't want a call back. That may work if you want to try it. To replace pump motor:
Take the rectangular recess out by using a putty knife on the left or right side, Remove phillips screws mounting pump. Pull machine forward about two feet to allow you to tilt the machine back to lean it against the wall. Reach under to access the pump. It is held in place by a plastic tab you can depress to remove, but if you break the tab, don't worry, as the mounting screws will hold your pump in place just fine when reinstalled. Remove pump by disconnecting hoses and electrical plug. Change out pump motor (three phillips head screws)
Posted on Nov 16, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 17, 2008
    Very unlikely you have an object causing the rattleing. Even if it is an object, you still will have to remove the pump to get at it.
  • 240 Answers
Sounds like you have possibly a drain pump failure where the impeller meets the motor shaft. To gain access, you will have to lean the unit back and get underneith the unit. The pumping unit will be above you on the left hand side. Be known, many LG's (which probably includes yours) have 2 pumps, one for drain, one for recirculation, and they both attach to a chamber, so be sure you replace the right one. This chamber is held on by a couple of screws, then you can move the whole chamber around and bring it back to the hole your working in. Let me know if you need further information.
I have an LG WM2277H that is displaying an OE code. I drained and checked for obstructions twice. When I tried it again, I put it on a rinse and spin cycle which started out at 31 minutes. It rattled pretty much from the onset and then stalled out at 25 minutes and then displayed the OE code again. After reading several posts, I followed all the recommendations and drained the water through the hose at the lower left of the front panel and pulled and checked the filter. All appeared clean. I disconnected and checked all the drain hoses for obstructions. Again, all is clear. Next, I removed the chamber that hold both the drain and recirculating pumps. I can't tell which one is which, so I ohm'd both of them out. I got 12 ohms on one and 22 on the other. I assumed from reading other posts that the rattling was the impeller that had come off of the shaft but when I pulled both motors from the chamber, they were both in place. HELP!??
Posted on Feb 15, 2010
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: LG WM-2277HB washer does not drain and make rattling noise.
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall to allow access to the pump through the large rectangular hole in the base of the washer. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Leaking is rarely, if ever, caused by the drain pump. Small leaks can come from using too much soap, which backs up in the dispenser area and leaks down inside the machine, or larger leaks from a cut in the door gasket.
Posted on Apr 04, 2009
Replacing the pump in my LG tromm
cheaper to check for a problem in the impeller first as the pump motor seldom fail but there are problems with items jamming the impeller
Oct 29, 2017 | LG WM-2277HW Front Load Washer
Our LG washer is 4-5 years old. All of a sudden there is a slight scraping noise when the drum is turned. I can feel no resistance when turned by hand. It sounds like something may be between the stainless...
My LG WM-2277HW Front Load Washer had the same problem, I took it apart and it turned out to be heavy corrosion on the drum. just sand it back and it will be as good as new
May 03, 2011 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
Apr 04, 2009 | LG WM2277HBW XL Front Load Stackable...
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
BOTTOM DRAIN HOSE LEAK
http://136.166.4.200/contents/Laundry/WM2277.htm
Try that website and download the service manual..
Hope that helps...
Aug 07, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,084 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
