Question about General Filters 1042-LH Humidifier
Change filter how do I change the filter on a General 1042-L humidifier?
Posted on Dec 09, 2008
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
There is no water going into the humidifier, make: Generalaire 1042
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
Apr 09, 2011 | General Filters 1042-LH Humidifier
I have a General Filters 1042-LH Humidifier in my home what setting should it be he choice low/ med /high live in Michigan
Sorry to read about your problem, I hope this helps you out.
-20F -29C 15%
-10F -23C 20%
0F -18C 25%
+10F -29C 30%
+20F - 7C 35%
+30F - 1C 40%
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | General Filters 1042-LH Humidifier
My 1042 L General humidifier is not putting moisture in the air eventhough water is getting to the filter
General 1042-L not putting moisture in the air. Water valve is open and getting to the filter. The unit is clean.
Dec 01, 2009 | General Filters 1042-LH Humidifier
How to fix 1042 Error
format your whole pc there may be some virus.......then install it
Jun 14, 2009 | General Filters 1042-LH Humidifier
What's the best way to clean a 1042 filter
best solution I have found to clean them is to buy yourself some (CLR) seems to work the best, I would recommend soaking as much of it as possible, the longer you let it work the better the results, hope that helped
Jan 19, 2009 | General Filters 1042-LH Humidifier
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
General 1042
The 1042 has a valve that operates on 120 VAC. The 1042-LH has a valve that operates on 24V.
Oct 13, 2007 | General Filters 1042-LH Humidifier
General Filters 1042-LH Humidifier Logo
785 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
