Question about Acer AL1916W 19" LCD Monitor
Acer AL1716 Monitor Troubleshoot
I recently re-installed Windows XP on my system and while re-installing programs and cd drivers I was asked to restart my computer so that the changes would take effect. However after restarting, my monitor loads up normal until it is to display my computer screen and it just says"Auto Config Please Wait" and that was since the night before. What can I do? Please help!
  • Acer Master
  • 5,568 Answers
You can try the following: - Early (very) in the boot routine tap either F5 or F8 to access a short startup menu - Choose 'Safe Mode' (this should give you some kind of display) If it does give you a screen; - Click Start - Select Control Panel - Open the System folder - Click on Hardware - Choose Device Manager - Find and open Monitors - Highlight whatever monitor is listed and delete it
With your monitor turned on and connected, reboot your PC.
I can't guarantee it but this may force Windows 'Plug and Play (or Pray)' to look for, find and then finally install some kind of driver (may not look like you want) to get your Desktop visible again.
Then you can adjust settings in the ontrol Panel's Display section.
Your monitor could be causing the problem but it is more likely Windows doing whatever it feels like (or nothing at all) again.
Posted on Nov 16, 2008
What is the system disc
that's proberly windows install CD.if you bought the computer with windows installed you have made them first thing.if you got windows install CD put in the computer let windows load it's files.choose to repair you computer.if you not have windows install CD.go to windows recoverypartition.you get there of tap F8,F10 OR DEL.there you got tools for recovery or go back in time.
Apr 11, 2013 | Acer Aspire X1301U9032 (PTSCM02007) PC...
My Acer Aspire T650 Computer came with Windows XP Home Edition installed on it. However, viruses invested the operating system and I had to do a fresh installation. Because the computer did not come with...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
I m having pirated windows 7 in system. i want to install windows xp. what should i do?
Use your Windows XP installation CD and the product installation code that is on a label on the bottom of your Acer.
Boot up with this CD click install Windows, then delete the existing Windows partition, create a new partition, then format this partition (do a full format not a quick format) then continue the installation as per the screen instructions.
After installing Windows, install the Acer Aspire device drivers, Activate Windows via the Internet or by phone, install XP SP3 (service pack) and your programs.
Jan 31, 2011 | Acer Aspire Notebook
I can only boot Windows XP up in safe mode on Acer Aspire 150 and I don't have a built-in CD drive. What do I do?
go to control panel look for add or remove programs see what has been recently installed and remove that program if it is not something that is vital to your operations.Also you can click on system and go into your device manager look for any cautions on installed devices remove or disable the device or re-install the drivers.
Jan 11, 2011 | Acer Aspire 5500 5570-2609 Laptop
Is there a way to get this monitor to work with windows xp??
It should have no problem as long as you have correct driver for your PC Video card, there is no need to install the monitor drivers. My PC for testing monitor is running XP as well.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 19, 2010 | Acer AL1716 F Monitor
My acer aspire 5002wlmi does not detect my hard drive during windows xp install,but hard drive can be detected and be access when i connect it to a desktop using it as xternal,..what seems to be the...
You can slipstream the storage controller drivers from the floppy disk image you download from Acer's web site into an ISO image of the Windows XP installation CD using a program like nLite.
You can then burn the slipstream ISO image into a CD & use it to boot & install Windows XP without the need to use the floppy disk.
You can download nLite at the following link:
http://www.nliteos.com/download.html
After downloading the installer, install the program & start using it.
The following link describes how to use nLite to slipstraem the SATA drivers into the Windows XP installation CD:
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
I tried this myself, & it worked without problems. I now no longer need to use the floppy drive when installing Windows XP on my system.
Aug 29, 2010 | Acer Computers & Internet
How to reformat acer aspire one
Put a Windows XP disk (has to be the full version not an upgrade) into the CD drive and the computer will ask to "press any key to boot from CD". Press a key. Follow the prompts, It is important to delete the partition when asked. Then recreate it. Format the drive with NTFS file system. The setup will go on to reinstall windows automatically.
Now, the only challenge is to reload any software drivers for components Windows does not find automatically. This is a little tricky. Do google search of Acer drivers or go to www.drivers.com.
Also, remember all your software programs need to be re-installed. For example, your Microsoft Office (word, excel, etc). Any games, any virus protection, Quickbooks, etc. The printer software also needs to be re-installed. Hopefully you still have the original disk or if its a Hewlett Packard go to their website.
Aug 15, 2009 | Acer Aspire One PC Notebook
How to install windows vista at acer aspire 4330 LAPTOP
HELLO I AM RAVICHANDRAN FROM iRELAND, I BOUGHT THE EEE PC 900 SERIES WINXP, I GB RAM CELERON 900 PROCESSOR. NOW WIDOWS XP IS CORRPTED, WHAT CAN I DO . I HAVE A USB DVD DRIVE. HOW IS BOOT THE BOOTABLE CD. PLEASE DETAILY EXPLAIN ME STEP BY STEP
THANKS
Oct 10, 2008 | Computers & Internet
SOMEONE RECENTLY REBOOTED OUR COMPUTER AND WHEN WE GOT IT BACK IT HAD NO SOUND ON IT. WE DONT NO HOW TO PUT IT BACK ON. OUR SPEAKERS CAME WITH OUR COMPUTER AND OUR COMPUTER MODEL IS AN ACER AL1716
Hi
u must hav got a Drivers CD when u purchased ur system. just run the cd and install the audio drivers.
hopefully u get the audio back.
if not, then just get back to me
Hitesh
9923888524
Jun 27, 2008 | Acer Computers & Internet
Blink problem
hi there, try to install direct x software, a driver software for video acceleration. ty
Feb 13, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
350 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
