Question about Canon BJC 3000 InkJet Printer
Canon bjc-3000 is not printing
I have a canon bjc-3000 printer and a compaq computer and everytime i tried to print something out it wont print. it wont even print a test page for me
Has the software for the printer been installed in your computer? Sorry if this sounds like a silly question, but I did the same thing, and it turned out I hadn't installed the software yet so it didn't recognize the printer.
Posted on Nov 16, 2008
Paper feed fault
Check the printer lens and make sure the paper is probely inserted. Hope this helps...
Jan 28, 2008 | Canon BJC 3000 InkJet Printer
Canon BJC-3000. Paper goes through but is blank.
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 24, 2010 | Canon BJC 3000 InkJet Printer
My canon bjc 3000 inkjet printer is feeding paper but not printing. Does the head need cleaning? How is this done?
could be possible that its either dired up or out of ink, open its bonet and remove cartages, clean head with a soft cloth removing any dried ink give cartages a good shaken see if any ink comes to head, and try again. hope this helps
Nov 30, 2009 | Canon BJC 3000 InkJet Printer
Paper jam(Canon BJC 3000)
Try to open the printer cover and look for tiny paper shreds that might got stuck between the rollers. Also if your printer has a sensor, there could also be a tiny piece of paper blocking it, thus sensing a paper jam.
Aug 31, 2009 | Canon BJC 3000 InkJet Printer
I have a canon BJC-3000. Do I have to replace my
Just select "grayscale printing" in the properties box for the printer. Open a document to print, when you get the "printer set up" box, select "properties, and look for a check box that says "grayscale printing" and check it. You will now print in B&W
Aug 24, 2009 | Office Equipment & Supplies
Cable for USB conversion
YES. THERE ARE SEVERAL USB-PARALELL CABLES CABLES IN THE MARKET. JUST CHECK IN THE WEB OR YOUR HARDWARE STORE. PRICE SHOULD BE AROUND 15 TO 20 US DOLLARS, DEPENDING ON BRAND, QUALITY, ETC.
SOME OF THE (MOST) BRIG A DRIVER CD.
ONE THING YOU SHOULD HAVE IN MIND IS THAT WHEN INSTALLING YOU BJC-80 IT WONT PRINT UNLESS YOU GO TO PRINTER PROPERTIES, PORTS AND UNMARK "BIDERECTIONAL COMPATIBILITY", THE GO TO ADVANCED OPTIONS AND CHECK ON "PRINT DIRECTLY TO THE PRINTER", OR SOMETHING LIKE THAT. (SORRY ALL MY SOFT IS IN SPANISH...) RESTART THA COMPUTER AND ENJOY. I HAVE A BJC-70 AND A BJC-80, USE THEM ON XP SP2 AND VISTA. BOTH WORKING FINE. DO NOT EXPECT SPEED PERFORMANCE. GOOD LUCK
Mar 10, 2009 | Canon BJC 80 InkJet Printer
Printer wont print
Try the simple solution first. Uninstall the printer, reboot and reinstall. See if you can print a test page from the printer itself to make sure it still works period. If you can't print the self test page (which is the printer talking to itself) the computer won't be any better.
Dec 03, 2008 | Canon BJC-85 InkJet Printer
Canon BJC 3000 InkJet Printer Logo
164 people viewed this question
old marine
old marine
