Question about HP PSC 1510 All-In-One InkJet Printer
Scanner will not connect to computer
When I open HP Scan in order to scan something, an error message reading, "Unable to connect to HPAIO TWAIN data source". The scanner is not broken because it makes copies fine. If i press "start scan" on the printer, the power button just blinks for about 20 seconds and then stops. What should i do?
    President:
  • 2,961 Answers
'Twain' only means 'Technology without an important name', as this is refering to your printer/scanner, i would suggest that you disconnect the printer and remove any driver from Add/Remove programmes. Re-install printer software/driver and re connect printer when prompted and if possible in a different usb port, if that's how it's connected. If the problem persists and the pc is unable to communicate with the printer the fault will lie with the hardware. Hope it's only a driver glitch.
Posted on Nov 27, 2006
SOURCE:
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
When I open HP Scan Pro and attempt to scan a document it tells me the scanner is not found. It is plugged in by USB correctly.
The computer is looking for a "Twain" device. Although the printer is correctly installed, to scan a document or picture, you need a program to associate with the scanner and identify the "Twain" device. To do this, open up any photo software or even MS Paint. Under the File tab there should be an option to Import or Import from a device i.e. camera, scanner. This is the option you want. Select your HP Scan Pro as the Twain device and you can scan from your computer. The other way would be to open HP Imaging software package that came with the machine and configure your scanner from within the program. Either way works its just a matter of preference. Best of luck and reply back with any questions.
Nov 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
My hp 5510 all-in-one won't scan photos
Unfortunately the 5510 is no longer supported by HP for OS X 10.5.x and up. On the Apple tech site, they actually redirect you to a page the HP upgrade page (read: buy a new one).
If anyone can think of any 3rd part software that works with this, please post!
Thanks!
May 01, 2009 | HP Officejet 5510 All-In-One Thermal...
My computer is unable to open twain driver
you may need to reinstall the twain driver at this time, or use a different application program inorder to scan
appreciate your kind comment
Apr 12, 2009 | Canon BJC S600 InkJet Printer
Unable to "communicate with TWAIN data source." ??
This may happen because of overload to memory. If all are ok and still this error comes up means, the twain driver takes more time to load. wait for some seconds and then click scan, it will go.
Try to clean the hard disk and defrag the drive.
Jun 02, 2017 | HP PSC 1315 All-In-One InkJet Printer
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
I get an error message 2019 and unable to connect to twain device
Make sure that your scanner cable is not tightened too much. I had this challenge and found that by simply loosening the cable connection, this error message dissappeared.
Sep 16, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
HP PSC 1510 All-In-One InkJet Printer Logo
606 people viewed this question
Clive
Clive
Thomas F. Schneider
