Question about Stoves 700DFa Dual Fuel (Electric and Gas) Kitchen Range
Top oven won't turn off.
I have a Stoves 700 DFa double oven and the top oven element wont turn off.  I have changed the heat sensor assembly and the top oven switch EFG-206 but the problem pursuits.Without a wiring diagram it is hard to know what else could cause the problem.Please can you help?
  • 1462 Answers
SOURCE: Fan oven stays warm
is the fan working when oven is staying warm? possible fault if you don't have an earth trip is a short to earth on the neutral side of the element
Posted on Mar 26, 2007
  • 1314 Answers
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Posted on Mar 15, 2008
SOURCE: stoves df 600 sidom
We had ours fitted by a Stoves engineer who said he had the same cooker. He also told us that sometimes the fan will stay on after you have finished using it. The reason is, there will still be heat coming from the cooker or grill after use. For that reason, the fan stays on for a bit afterwards. Its just a safety precaution so that the knobs dont get too hot.
Posted on Jul 20, 2008
  • 139 Answers
SOURCE: Removing door on top oven
Pus the top part of the hinge down as it is on springs and try and pull is out.
Its hard to explain this.
or you can try to squeeze the two parts of the hinge to force the top part down, and basically yank it out.
I have to say again it hard to explain but thats the basic procdure..
Dont give me a bad rating please im trying to help ya
washdoctor
Posted on Aug 25, 2008
  • 3 Answers
SOURCE: Top oven thermostat Stoves 800DF - fitting?
you dont need to remove the front panel, you need to undo the two black screws on the side of the hob unit, remove the two plastic plugs they went through allowing you to raise the hob, and remove just the back off the cooker this provides you access to all the areas you need you can then follow where all the cables go oh yes nearly forgot the thermostat is held in place by two screws you simply pull the knob off and there they are. ive just done the fan oven one and it seemed fairly straight forward, but please do remember to turn off the power to the cooker first all the connections push on using spade connectors, oh yes for legal reasons this is for information only and i wont be held liable for injury or damage caused by unqualified people following this information to fix it themselves as i would always have to recommend that you use a competant person ie a person who is trained, experienced and has sufficient knowledge to do the job, but those that do want to fix it do so at their own risk and i hope all goes well with getting the problem fixed
Posted on Mar 27, 2010
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Aug 02, 2011 | Stoves 720EF Electric Double Oven
Hi, my Stoves 720EF is 16 years old. We have had no problems until today when we noticed that the main oven was not heating up. The light and fan come on, but no heat. The timer is not set. We have...
Peter
ISOLATE MAINS POWER BEFORE WORKING ON ANY APPLIANCE
It sound like an element problem, but, you need to investigate, before we can go ahead to define the exact problem, the varistate control is working because the fan operates.
Remove the ovens, remove the rear and may have to remove the top, or sides, remove the bottm fan, you should be able to vue the element, look for Black Grey burnt blow out, not carbon or food spots, if you see or feel a rough spot on the element, it probabily is blown. Replace heating element. Seach in whitegoods.co.uk for part, you will need model and serial numbers.
Hope this has been helpful
John
May 17, 2011 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
BE CAREFUL.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
I have a double oven top one stopped heating up sooo i just switched the elements from the bottom to the top as to order the parts but that isnt the problem the top still won heat up
This could be a faulty circuit or sensor that will need to be replaced before the oven safety feature will disengage. If the Temp sensor is not registering as working or the load sensor it will not allow the element to heat up. This is a safety feature. You will need a repair tech to diagnose this and do the repair.
Oct 17, 2009 | Frigidaire FEB27S5A Electric Single Oven
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Stoves 720ef top oven warms but does not reach high temps. element replaced - no fix. thermostat ok as heating light cycles on and off at around 120 deg C, but reluctant to get hotter.
Have the same problem. Went and bought an oven thermometer from Lakeland and found that when the top oven thermostat was set to 160, the temperature only got to 140. I did clean the sensor inside the oven using a cleaner from Lakeland which did improve matters but it is still running cooler that it should. ( It takes at least 20 to 30 mins to warm up)
May 01, 2008 | Stoves 720EF Electric Double Oven
Stoves 700DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
85 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
