Question about Denon Audio Players & Recorders
Hello, I have a Denon AVR-1906, Until recently we just plugged in our xbox 360 console into the back of the tv via the scart and the optical cable into the front on the Denon marked for games, all worked fine until yesterday have you any ideas please? the sky box and dvd all go throught it and work ok. also we have checked the optical cable and that is ok also. Many thanks Mr and mrs Woolley over 60 and Halo Freaks but not hight tech
  • 4234 Answers
SOURCE: Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Posted on Jun 17, 2008
  • 119 Answers
SOURCE: We have a Denon AVR
HDMI input connect as follows:
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Posted on Feb 28, 2009
petraman7
  • 1175 Answers
SOURCE: Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Posted on Apr 11, 2009
dunnbiker
  • 8546 Answers
SOURCE: Denon AVR 2106 clicking noise
I like when a user is observant and curious. That will help immensely in resolving this problem.
What source(s) are always involved with the problem?
You imply it is observable with output video to the TV - "only when there is movement on my tv screen and it stops in still screen". That sounds like a digital pathway problem of some sort as any data errors would eventually escalate to something audible or visible to you once the hardware and correction algorhythms are exhausted. The clicking inside the receiver could be its efforts to resynchronize with a bad data stream. Hence, I'd like you to isolate the ins and outs that fail all the time and find the probable single source of the problem.
Try this: put a digital source on and select/deselect it for listening or viewing. Does it make the click in that brief time it's 'thinking' before you hear the source? That would be the 'normal' sound. My Pioneer does it once per source switch. Repeated clicking would mean it's struggling.
I'm betting you have an optical or hdmi cable that's flaky or not in tight and straight. Or, if only one extternal source is involved we follow that back.
Posted on Apr 29, 2009
SOURCE: Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Posted on Jul 20, 2009
How should I connect my denon avr 1906 to my 32" ES6300 Series 6 SMART 3D Full HD LED TV Model numberUE32ES6300U in order to get dolby digital from the tv's tuner please?
Use an optical cable.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Sep 08, 2014 | Denon AVR-1906 Receiver
Tip
How to set up your xbox 360 without causing overheat
take everything out your new xbox 360 packaging. there should be:
1)a console (obvioiusly)
2) a cable that connects your 360 to a power block
3) a power block that connects your xbox to the wall
4) a cable that connects your xbox to the tv
5) a small rectangular box that connects your cable into the scart port on your tv.
lets begin
take the cable and connect it to the power block and move the power block to the side
take the scart plug (small rectangular box) and connect the yellow white and red wires into the approprite slots (these are marked out on your scart plug) and move to the side
pace your console down 90 deg. on its side in your desired position.
WARNING WARNING WARNING WARNING WARNING WARNING WA
do NOT place your xbox 360 standing up as this can cause red ring of death syndrome and other known xbox killers due to overheating i am on my second 360 as i never followed my own advise.if you keep your console standing straight it can cause vibrations which knock your cooling sinc out of place. it can also scratch your games more easily and ring them making them UNPLAYABLE. now place all cables you set aside and connect them into appropriate slots on the back of the console. and connect them into wall socket and tv.
thanks for reading.now wheres the free cake i was promised.
on May 15, 2010 | Microsoft Xbox 360 Console
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
HAS SOUND BUT NO PICTURE, IT IS NOT THE TV CAUSE THEY ARE PRETTY NEW. ALSO HOOKED UP A PLAYSTATION AND IT WORKED.
I had a similar problem. Don't worry, it's probably something really simple.
1) First check you component HD AV cable:
Is it properly plugged into the back of the XBOX? Push it in with a bit of force until it snaps into place
2) Check the Red, White and Yellow leads. Are they going to the right connections?
3) If you are using the Scart connection or a connecting your XBOX to your TV via a DVD player check all the Scart connections to see if they haven't come loose and if they have, push them firmly back in.
One of those is likely to be the problem.
Oct 05, 2009 | Microsoft Xbox 360 Console
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
Apr 29, 2009 | Denon AVR-2106 Receiver
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
Jan 08, 2009 | Denon AVR588 Receiver
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
61 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
