Question about Saeco Vienna De Luxe Espresso Machine
Our Vienna, Superautomatica leaks water from underneath
Every time we make espresso it leaks water from underneath the espresso side of the machine.
  • Anonymous Dec 04, 2008
    I want to change the o ring
Your problem may be in the watertank. I had that problem, and found out, the metalfeder fastened so it stayed open, after making a cup of espresso.
Posted on Nov 23, 2008
Saeco Vienna superautomatica leaks when making coffee
This is an easy fix for a 14$. The seal at the water tank connection is worn. Take the water tank off. There is a round flat topped plastic retainer. Pry off the retainer (comes off easily). You will see a black round o-ring made to fit on a channel. Remove the o-ring and replace.Two minutes and you are without water leaks. I do not remove the tank to fill anymore, I use a pitcher instead. Part number 3 in this diagram.
http://www.partsguru.com/user/VIENNA%20PLUS%20DIAGRAM.pdf
Jan 21, 2013 | Saeco Vienna Espresso Machine
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Water leaks from underneath the machine
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Sep 26, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
What is the difference between a water tank with & without a magnetic float on a saeco Vienna Superautomatica?
Hi
The magnet tells the machine that the water is low so you don't run the pump dry and cause it to fail. Some Vienna Supers had them and some didn't.
Jan 01, 2010 | Saeco Vienna SuperAutomatica Coffee...
Won't brew
water puddling underneath machine indicates a broken boiler.
Machine needs to be sent in to have the boiler replaced.
Do not continue to use the machine because the seal on the boiler which is broke can end up splashing the electronic board and rendering your machine a paper weight.
Jul 06, 2009 | Saeco Vienna SuperAutomatica Coffee...
Water Tank Leak
i had the same problem what i suggest to you clean where the water tank were its sit very good put the tank back me i never remove the water tank i clean regualy i put the tank empty on the machine and fill it with a glass never leak again pierre
Dec 08, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
249 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
