Question about Teac PowerMax 2000 Computer Speakers
NO SOUND FROM TEAC POWERMAX 80/20 SPEAKERS
POWER ON,, SPEAKERS PLUGGED INTO COMPUTER, BUT NO SOUND COMPUTER CANNOT INSTALL ?
You need to try them on another computer to make sure the sound card is working correctly in this one first. This will let you know if there is something wrong with your speakers.
Posted on Nov 16, 2008
TEAC turntable connected to Phono Plus which is connected to iMac, why no sound through computer speakers>
You should check the sound interface on your computer. It could be that the line in is muted or set to low.
Mar 30, 2015 | Teac Audio Players & Recorders
Hi! I have a problem with desktop speakers, buzzing sound without reproduction from sound card...other speakers work properly, so obviosly it is a problem with the speakers..the power suply is ok, diode is...
Are this powered speakers connect to the same mains power socket as the computer.
If not you may be getting an earth loop which causes a humming sound.
Connect these speakers to the same power outlet, if you have not sufficient outlets use a power board.
Apr 26, 2011 | Teac PowerMax 160 Desktop Speakers,...
No sound from as500 speakers
Hi there. If the sound bar is plugged into the monitor you also have to make sure that you have the cable from the bar plugged into the audio jack on the pc which is the pale green port. Hope this helps Mark
Aug 22, 2009 | Dell AS500 Sound Bar Computer Speakers
Where can i download the drivers for Teac PM 500 speakers from?
you don't need drivers
you must set your soundcard to 5.1
take a look for your speakers specs. here:
http://www.epinions.com/S0502246-PowerMax_500_2
Jul 06, 2009 | Teac PowerMax 500/2 Computer Speakers
I have plugged in my speakers and there is no sound i have gone into control panel and its not on mute
Plug some headphones into the same output that you had your speaker in. If they work it is your speakers. If not, then it is your computer.
*If it is your speakers, just the power is plugged in, the power button is on or replace.
*If it is NOT your speakers, then it is your computer driver. Uninstall and then restart. The computer will reinstall the driver automatically. Make sure you have the driver or have download it in case the computer doesn't install it for you.
Dec 21, 2008 | Logitech Z-2300 Computer Speakers
Computer speakers no sound
I'm assuming Windows XP on a PC Desktop but the concepts are the same no matter what operating system.
1. Are your speakers plugged in to a power source?
2. Are they turned on?
3. Is the volume turned up on the speakers?
4. Are your speakers plugged into the (usually green) audio port on your computer? 5. Go into control panel, sounds and audio devices and check to make sure that sound is not on "mute".
5. On the Audio tab, check to make sure it shows a default sound device for each item. If not, either your sound card is malfunctioning or you need to download and install a current driver from the Acer website.
Dec 12, 2008 | Acer Aspireā„¢ T180 PC Desktop
Teac x-20
do you have a sound card?
check if their is a driver installed for the speakers.
Jan 17, 2008 | Teac X20 Computer Speakers
Teac AG V8050
try using an antenna.
Dec 09, 2007 | Teac AG-V8600
Speakers set up properly, but no sound from PC
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer. But there is no sound at all coming out -- just silence.Can You Please Help Me
Oct 16, 2007 | Koss HD 50 Computer Speakers
Teac PowerMax 2000 Computer Speakers Logo
230 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
