Question about JVC Televison & Video
My JVC th-551 DVD player is saying 'no disc' after giving the 'now reading' message for a long time.
    Genius:
  • 1,847 Answers
Did you try a good know working dvd?
Posted on Nov 16, 2008
  • Legin Varghese
    Legin Varghese Nov 16, 2008
    The first thing that you should try is to clean the lens. there are many dvd lens cleaner in the marker and online (EBay) . and also let know how old is this dvd player.
I have made several attempts to play a disc on my JVC TH-V70. IT reads 'reading' on the dvd unit then after a few second the disc ejects. Why is this happening?
Hi Adrienne - If it only happens to the one DVD it is most likely a problem with the DVD being damaged or dirty.
If it's happening with all your DVDs your player laser lens is probably dirty or it might be damaged. If no discs are being read get yourself a CD/DVD cleaning disc and run it a couple of times (following the directions). Of this doesn't work you will have to decide if the player is worth the price of a repair (unless it's still under warranty). Most aren't as you can buy decent players for less than $50. Any repair will cost at least that.
If it is the one disc I suggest you take a clean soft cloth and wet it slightly with plain water and the give it a few strokes across the disc (not in circles), let it try dry for a few minutes and try it again. Also examine the disc (bottom) for any obvious scratches or stuck on gunk.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 28, 2011 | JVC TH-V70 System
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
JVC TH-C30 dvd movies skip
Check your formatting on the DVD recorder, you need to finalize the disk to be playable on "any" player. That should solve the issue. Your JVC is looking for specific code as it reads the disc, when it's missing or not understood by your JVC it will either stop play or skip over it's interperated missing info. Hope this helps
Jun 23, 2009 | JVC TH-C30 System
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
Jvc th-c50 will not read disc.
first of all check the region of the DVD player & the DVD disc. Well, you could try this link, to help you crack the region restrictions on your DVD Player.
http://www.digitalpinhead.com/dvd-unlock/?pu=false&srec=true
Hope this helps:)
Oct 19, 2008 | JVC Televison & Video
Disc error
Assuming you've tried regular nonrecorded DVD discs, there are many things that can cause this:
Dirty or defective laser. (try a cleaning disc).
Disc not spinning.
Laser not moving on slide rail.
I would at least try cleaning the laser lens before giving up.
Hope that helps...
Geno
Mar 24, 2008 | Televison & Video
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
Playing dvd's
The laser lens in your player might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more. P.S. please use line breaks between paragraphs and one "dot" at the end of a sentence is enough.
Nov 30, 2005 | JVC TH-A9 System
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
