Question about JVC TH-A10 System
Sub won't power up
I got a jvc th-a10 system, everything was working fine until it was unhooked by the guys who was replacing my floor. Now it won't work, the powered sub is plugged in but the power on indicator lite is off, any suggestions?
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Posted on Mar 01, 2009
Jvc th-m303 sub woofer not working all other speakers are fine
check your internal wires inside subwoofer.b4 that try to connect to other instrument to make sure it not working.
May 12, 2009 | JVC TH-M303 System
Jvc th-c30
sharazanct I had the same problem and posted here many months ago without any success. Just today, believe it or not, I decided i would replace the screws in the top cover and try it one last time. I don't know why, but it now works fine.???? My original problem was my receiver would light up and appeared to be working but I would get no sound out of the sub or speakers. I noticed at the time when I would first turn the receiver on the green indicator light on the front of the sub would light for a couple of seconds and then go out and would get no sound. Today the sub light lit and stayed on and I'm therefore able to hear sound as if everything was normal. I wish I knew exactly what I did, unfortunately I don't. If you have everything back together you might try unplugging the receiver and sub for some amount of time and come back and try it again. Good Luck!
May 04, 2009 | JVC TH-C30 System
JVC L-A10 won't turn on
the two issues are unrelated. a few turntables won't show life until the tonearm is moved over to the record area. at this point the motor should start turning wether it has a belt or not.
Feb 03, 2009 | JVC TH-A10 System
Won't Turn On
Try reseting the system. Instructions below.
Jun 01, 2008 | JVC TH-A10 System
Subwoofer
often your sub need to be change because of its malefunction.
Mar 09, 2008 | JVC TH-M303 System
JVC TH-A10
Have the same unit and it does not have the capability to play anything other than commercialy produced CD's or DVD's i.e. no CD-R CD RW
Dec 25, 2007 | JVC TH-A10 System
JVC TH-A10 Won't TUrn on...
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Aug 25, 2007 | JVC TH-A10 System
SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Oct 21, 2006 | JVC TH-M505 System
JVC TH-M505 powers off right away
The unit is going in to shutdown. My guess is a failed output. Service is going to be required.
Sep 20, 2006 | JVC TH-M505 System
JVC TH-A10 System Logo
371 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
