Question about Gaggenau EB294/295 Electric Double Oven
Bottom oven not working
Top oven works great. Bottom oven light comes on but no fan and no heat. Indicator light measures temp but doesn't tell me that it is heating up (because it is not). Brand new just installed. Why would the top oven work but not the bottom?
  • ednatalie Sep 22, 2008
    same problem but the unit is 14-year-old model EB-868-6, bottom just stopped heating...
  • Anonymous Feb 22, 2009
    the top oven light up and work very good but the bottom one no light no heat
  • 27 Answers
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Posted on Jun 26, 2007
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
Oven was heating and we got HEAVY smoke....
Nothing in the elements, thermostat thermocouples are gas filled, sensors have wiring inside, nothing in the liner or insulation. You said this was a stove, and some stoves have a vent that goes up through one of the burners on the top. If you had oil splatter or drip into this it can get into your oven. We do know that some blower fans on convection ovens have a sealed oil bearing, but there would be very little oil coming out of this (drops) and you will notice your fan getting noisier or running slower in the near future. Good Luck, Appliance Specialists
Jan 25, 2010 | Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Jan 14, 2009 | Baumatic B904SS Stainless Steel Electric...
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    WHY WON'T MY OVEN HEAT UP?
    Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
    Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
    Gaggenau EB294/295 Electric Double Oven Logo
    382 people viewed this question
    Top Gaggenau Ovens Experts
    Dennis Boxerman
    Jaime Hernandez
    ashburton
    Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
