Question about Radio Communications
Uniden president ssb base no transmit and no receive how to fix
I have no Recive No Transmitt No signal on meter How to fix
  • 2 more comments
  • Greg L Schulz
    Greg L Schulz Apr 24, 2012
    Hmmm it is a Uniden Base just says President on it chkd Mic is ok no trans or receive but hooked up another radio and thru dummy load it has modulation when keyed no meter readings tho on trans or recive
  • Greg L Schulz
    O....................K #1 It is a 8719 chip #2 got receive now thanks Found solder bad on ic mod chip No transmitt tho and no meter movement on receive or transmitt but on dummy load and extra radio can hear mod on extra rig on transmitt Possible finals? and what about no meter movement
  • Greg L Schulz
    No Radio has not been modified at all the cans are all still sealed and Receive is back but no Transmitt and is on reg channals receives great now but still no trans on am or sideband and no meter movement at all
  • Greg L Schulz
    Greg L Schulz Apr 25, 2012
    Hmmmm any idea where I can find the replacement final and driver? I beleve its a 1306 an 1307 Don,t think they stock those anymore
    Top Expert:
  • 14,553 Answers
Have the mic checked first to make sure wired correctly and or wires not broken where connect to plug----also check to see if same on SSB and Am.
President what? Madison, Lincoln etc.
Posted on Apr 24, 2012
  • 3 more comments
  • SD Tech
    SD Tech Apr 24, 2012
    will be on plate on rear which it is---not front.
    As old as it is first issue is this one or two problems--I would begin by checking the voltage regulator and other chips that are bolted to the sidewalls of the radio--it is not uncommon for the folded over pins to break loose and just need soldering.(audio chip if it has it--should be there can cause this.)
    Then quickly with unit off and not powered test the driver and final to see if open or shorted---There are a few other possible reasons---some of the real old ones use a UPC1148 or a number like that for the audio output---no sound will equal no audio at speaker but if it modulates that is likely good--follow the suggestions and let me know what happens.
  • SD Tech
    By the way--what PLL chip is used? 858?
  • SD Tech
    has the mb8719 been "altered" ? what you could have is it is not when showing 19 etc there but somewhere else----like way up or down and actually on another freq.
    If not modified final will not kill receive---keep looking--find one bad connection you may find more---if it has been modified for extra channels there will be leads soldered to pins on that PLL---inspect them to make sure not broken loose etc.
  • SD Tech
    check driver and final (they are base-collector-emmiter) and should have dc when keyed on middle pin---ohm them (may have to unsolder all leads) to be sure not open or shorted----you know how?
    If one is open or shorted replace both---radio has a AM reg transmit transistor but ssb would still function and transmit even with that bad---not a bad idea with no power to read from center pin on either driver or final to the board ground--cans etc---no short there can exist---metal frame of radio is a different ground.
  • SD Tech
    SD Tech Apr 25, 2012
    there are replacements but not as high a output--call for example Suburban Electronics with the generic numbers on the two and they will have replacements--can also google the generic to see which replace them--think one is 2sc2166 ---number on original will be 2sc1307?
SOURCE:
Benimur
  • 6966 Answers
SOURCE: No Modulation!!
Most modulation problem could be traced to:
1. mic or the cable and/or the mic connector;
2. AMC (amplitude modulation control) - it's a single transistor that regulates modulation and occasionally has been known to clamped on the mic audio;
3. the AM/SSB switch - spraying with contact cleaner is a temporary remedy; and/or
4. audio amp - however if your receive audio is good, then this does not apply.
Hope this be of initial help/idea. Without a model number, I can't be more specific as to component(s) or PCB location but pls post back for any developments (or lack thereof) or should you need additional information.
Good luck and kindest regards.
Posted on Feb 09, 2008
SOURCE: No AM carrier or modulation. SSB transmits good
Great now check TR42 AM POWER then check TR41 AM POWER REG. They are on right side twards rear of board with front of radio faceing you part side up. A good place to start!
Posted on Jul 07, 2007
Shuttle83
  • 1139 Answers
SOURCE: president mckinly ssb/am model with mb8719 pll chip.
It looks like you had some loose connections in that CB. you may want to also check for other cold solder joints throughout the units and touch them up with some solder. Might I suggest you use a desoldering tool and then just add new solder to the connection.
Posted on Sep 05, 2007
  • 32 Answers
SOURCE: uniden president grant stops transmitting
this sounds like the AM regulator has lost All of its smoke.(thats what electronic parts are made of) If this is A Grant the AM regulator is located in the rear right hand side of the radio.If it is a grant XL this is located on the very back of the radio on its on little circuit board.check this part part to see if is your problem.one other way that you can tell if this is the problem when it stop transmitting check it on side band (LSB or USB) to see if it transmitt.If it does that is most likley your problem.
Posted on Feb 02, 2009
  • 219 Answers
SOURCE: uniden grant ssb cb, receives but no transmit,
test your voltage regulator and make sure you don't have a bad crystal
Posted on Dec 16, 2009
Why no modulation in transmit mode?
Without seeing it I would guess (and it's only a guess) that maybe you have a broken microphone wire. If it's a factory mic the most common place for it to break is right up from the mic plug. Factory cords are not flexible, their really stiff. We could really use some more information. Mike
Oct 15, 2015 | Uniden Radio Communications
Why is there no transmit modulation?
'mic gain' adjusted for optimum amount of modulation?
Oct 15, 2015 | Radio Communications
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Oct 06, 2012 | Uniden Solara DSC VHF Marine Radio
Ihave a gargeled recive sound
Check the position of the mode selector switch. You may be receiving a SSB (single side band) transmission that is not on the exact same frequency as you or, your radio is in AM or FM mode. You will need to select either USB or LSB (upper or lower side band) and vary the clarifier knob until the sound becomes intelligible. If the sound does not become clear, try the other side band and repeat varying the clarifier knob.
Conversely, if you are in USB or LSB mode and there is a transmission on AM or FM, it will have the same garbled sound. Try changing the mode to AM and the FM. If it does not become clear, it is likely a SSB transmission and you are not on the exact same frequency of the transmission you are hearing. Vary the clarifier knob until it becomes clear - or change to the other side band if needed and try the clairfier again.
The short story is that you must be in the same mode and on the same exact frequency. When in AM or FM, this is less of a problem as these are much more wide banded signals than SSB signals.
The 2990 is really a 50 watt 10 meter amateur radio - but is geared to CBer's as it is easily modified to work in the CB frequency range and the so called "free band" between USA's CB (11 meters) and worldwide amateur 10 meter bands. Be careful transmitting this radio on CB frequencies as it violates FCC rules for power output there - and transmitting in the 28MHz - 29.7MHz requires a valid amateur radio license. Fifty watts on ham frequencies is tiny compared to the 1500 watts permitted. Why not get your ham license (here's how) and leave the "Chicken Band" (and all it entails) behind. You won't miss it!
I hope this helps and good luck!
Apr 12, 2012 | Cobra Radio Communications
Receive is ok, but when I transmit on SSB the Freq. jumps 10KC. What adjustments can I do to get the transmit back on Freq. without effecting the Receive?
go to you tube and type in your radio make and model and watch the review on that radio there is a freq adjustment pod for ssb adjustment. they might tell you if not take it to a radio tech and he should be able to alighn it. there is more than one pod for ssb transmitt and receive.
Mar 21, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Uniden president grant stops transmitting wait 1 or2 minutes and it will transmit for a little bit then does it again never lose my recieve thank you for your intrest
i cant afford 20 dollars to fix that radio your add said free i am laid off the old grant will have to waite i am not a teck have no idea what is wrong thank you for your time sorry to bother you ihave a good ole cobra29 that i talk on now [email protected] yahoo.comm
Jan 30, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
President mckinly ssb/am model with mb8719 pll chip.
Jul 31, 2007 | Cobra 19 DX III 40-Channels Base CB Radio
Radio Communications Logo
402 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
