Question about Compaq Computers & Internet
Type is going off the screen
I recently had to do a system recovery on my computer, which went OK, however I notice the type is going off the screen on the left side. Is this a monitor adjustment or a computer adjustment?
    Problem Solver:
  • 18 Answers
Download microsoft cleartype for LCD , allso make shure u have correct driver for lcd.
Posted on Nov 16, 2008
Emachines recovery management
Click the Windows "Start" menu and choose "All Programs."
Navigate to "eMachines" and choose "eMachines Recovery Management."
Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password.
Type a new password in the text box and click "OK."
Click "Restore System to Factory Default."
Type the recovery password and click "OK."
Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart.
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
Feb 06, 2014 | Computers & Internet
I want to do a fyll system restore
Hope this helps
Oct 23, 2012 | eMachines T3256 Drivers Recovery Restore...
WINDOWS XP PRO CAN`T RUN SHELL32.DLL,CONTRL_RUNDLL WSCUI,CPL
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
or
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer.
Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner.
Do not disconnect the keyboard, mouse or monitor.
Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
hope this helps
Oct 14, 2012 | E-Machines W6409 (7234) PC Desktop
Factory restore
If your particular eMachines model didn't come with recovery media or you just misplaced the disc, you don't want to be caught without a means to restore the operating system.
It's all too easy to accidentally download a virus or experience any number of problems that make your computer unstable.
However, there is an option for restoring your computer without the original recovery disc by using the pre-installed recovery software.
Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your internet settings.
hope this helps
Sep 21, 2012 | eMachines T2862 Desktop PC 2.66 GHz...
Hp pavillion 560w computer factory system restore feature does not work i can launch the system restore feature and it starts ok and asks me to confirm this action so i say yes and then on the next...
hELLO THERE
thank you for choosing fixya
ok here is the best way to hopefully take care of this that i have used on several older hp pavillions
when you go thru the recover system and you get to the black box and it says no device found or something similar at the command prompt type list and then press enter and it will give you a list of the 2 drives like c: /hp-recovery fat 32 and d: / hp_pavillion when it does this exit and type in the recovery drive with colons like this d: then type cd\windows\system32 then press enter then at the command prompt type rd /s catroot2 then press enter and answer y to the next screen then type exit and then once it has exited now shut down the computer if it does not do this for you
now upon restart it should recover your system automatically with no problems ok
please feel free to rate this solution
best regards mike
Jan 03, 2011 | HP Computers & Internet
How can i restore back to factory condition without the disc?
Use the following steps to recover the computer from the Windows XP desktop:
  1. Backup files from the My Documents folder and from other folders you may have created.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. From the Windows XP desktop, click Start , All Programs , and then one of the following options:
    NOTE: The following options are for HP computers. Compaq computers will have similar options (for example, Compaq Tools).
    • HP Tools , and then HP PC System Recovery .
    • Hewlett-Packard , hp pavilion pc tools , and hp pc system recovery .
    • PC Help & Tools , and then HP PC System Recovery .
    c00370937.jpg A recovery Welcome screen appears.
  4. Click Yes or OK to continue the recovery process. The computer restarts to the recovery program. If another welcome screen is displayed, click OK to continue.
  5. Select one of the following procedures, depending on which recovery type you want to perform:
    • To perform a system recovery, click Next , and then click Yes
    • To perform a destructive recovery, click Advanced , (select Destructive Recovery ) and then click Next .
      CAUTION: A destructive recovery will format the hard drive. This will delete all the information on the hard drive and reinstall Windows XP and the original software that came with the computer.
  6. Read and respond to each window and screen that appears.
  7. After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the PC finishes the setup.
    NOTE: It may take a long time to complete Windows setup. This time varies and may take over several hours. Recovery times are most affected by using recovery discs that were ordered from HP and/or the amount of files that were stored in the user account folders (for example, My Documents and the Desktop).
  8. Before using your computer, update and protect your computer. For more information, refer to Things To Do After Performing a System Recovery in Windows XP .
  9. Re-install applications that you added after purchasing the computer, and any files that you have backed up.
Nov 27, 2010 | Compaq Presario 5000 PC Desktop
I need to do a factory restore on a 1012 mini how? the f8 thing does not seem to work.
you can only do this type of recovery on certain machines --contact manufacturers site for original "specs" etc
Sep 07, 2010 | Dell Inspiron Mini 1012 Netbook PC
Computer is keep rebuting
Access the Recovery Console and extract a new copy of the Kernel32.dll file from the original WinXP CD
1. Start recovery console as described above
2. Insert the WinXP CD
3. At the command prompt, type CD system32, press ENTER
4. Type ren kernel32.dll kernel32.old, press ENTER
5. Type map, press ENTER
6. Go to the drive that contains your CD
7. Type expand drive\i386\kernel32.dl_, press ENTER; Kernel32.dll should be listed as 1 file expanded
8. Type exit, the computer restarts
9. Remove the WinXP CD
  1. Check cpu for dust
  2. Run a virus scan
  3. Check power supply
  4. Check other hardware such as memory
[Start] [Run] [Regedit]
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\CrashControl
Modify/Create the Value Data Type(s) and Value Name(s) as detailed below.
Data Type: Dword // Value Name: AutoReboot
Setting for Value Data: [0 = AutoReboot Disabled / 1 = AutoReboot Enabled]
Exit Registry and Reboot
Open System Properties via Start > Control Panel > Performance and Maintenance > System
[ System Properties may also be opened using the WinKey+Pause key combination ]
Select the Advanced tab and then click Settings in the Startup and Recovery section
In System Failure section, clear the checkbox next to Automatically Restart
Click OK and OK to exit
  Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!! yuva
Mar 26, 2009 | Dell Dimension 4500S PC Desktop
Windows not starting successfully.
You must remove all usb devices and any hadware you have recently installed if this problem still occures you will need to reinstall windows xp
Jan 11, 2009 | Computers & Internet
Cant access router screen or get on the internet after updating the firmware
If you have updated the firmware for your router and you can no longer access the router screen please follow these steps and you will regain access to that screen. In the browser address bar type in http://192.168.2.1:88/login.htm. If you still cannot access the screen, follow the instructions below. FOR Win95, 98, 98SE, ME: 1. Right click on Network Neighborhood. (you should see the icon on your desktop, or for winME it will say My Network Places) 2. Double click on TCP/IP for your network adapter. 3. Select ?Specify an IP address? and type in 192.168.2.41. For the Subnet Mask use 255.255.255.0 4. Then click on the DNS Configuration tab and select Enable DNS. For Host name you may assign whatever name you prefer. (ex: your name, or your computer name) Leave the Domain name blank. Under DNS search order, type in 4.2.2.1 and click add. Then add 4.2.2.2. 5. Click on the Gateway tab. Under New Gateway, type in 192.168.2.1 and click add. 6. Then click ok. Click ok again and you should be prompted to restart. 7. Once the computer is restarted, open your browser and in the address bar type in 192.168.2.1. You will get the router login screen. If you get a screen that says Recovery Micro Code, that means the update didn?t go through and you will need to update it again. For Win2000, XP: 1. Go to your control panel and double click on Network Connections (for winXP you have to select Network and Internet Connections, then Network Connections) 2. Right click on your Local Area Connection and go to properties. 3. Double click on Internet Protocol and your TCP/IP properties should open up. 4. Select ?Use the following IP address? and type in 192.168.2.41. The Subnet Mask should be 255.255.255.0. 5. For the Default Gateway use 192.168.2.1. 6. Select ?Use the following DNS server address?. For the Preferred DNS server type in 4.2.2.1. For the Alternate, type in 4.2.2.2. 7. Click ok, then click ok again and restart your computer. 8. Once the computer is restarted, open your browser and in the address bar type in 192.168.2.1. You will get the router login screen. If you get a screen that says Recovery Micro Code, that means the update didn?t go through and you will need to update it again.
Feb 16, 2006 | Belkin (F5D5230-4) Router
Computers & Internet Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
