LG 42LC2D 42 in. LCD HDTV Logo
Lisa M Posted on Apr 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The left half of my LG LCD TV is going bad. Can anyone suggest a fix before we have to pay a repair tech?
I've been getting intermittent pixels on all channels on this TV and now when it's turned on the left half of the screen is totally messed up but after a while it goes away (for now). This TV is almost three years old. It's getting worse daily and I'd sure appreciate any help greatly!
  • lbclilmo
    lbclilmo Nov 08, 2012
    OMG i'm having the exact same problem with my LG 42" LCD tv that is 3 years old. I was told that the LCD was bad and that it would cost me $624 to fix. I don't know what to do with this tv.
Ezra Young
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 15, 2012
Ezra Young
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3087
Points
I just fixed this problem on my friend's a couple of days ago. It is indeed the tcon board. It does not need to be replaced though! I just took it apart, cleaned the grounding connections with isoprol alcohol, and double checked all connectors. Turned it on and it worked great! I hope this helps yours and anybody else's problem! A lot cheaper than sending it in for repair. Don't try this if you're inexperienced at fixing electronics though. There are some high voltages built up in the power supply.
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Apr 24, 2012
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986853
Points
237762
The T'Con board might be faulty. You have to check all the connection strip wires goes to in and out for any loose. T'Con [Timing Control Board] board is one which controls the pixels on the LCD screen.
Testimonial: "Thanks so much for all your help. You've been awesome!"
  • Lisa M Apr 24, 2012
    Thanks for the help... Would this possibly explain why the left side of the TV keeps looking scrambled now? It's intermittent at this point but sometimes completely wipes out the left half of the screen and then after a while it seems okay again once the set has been on for a while. I'd really appreciate any added advice!
  • The Knight
    The Knight Apr 24, 2012
    It will be best to get the set repaired by any well experienced service technician. Because, the strip wires that goes in and out to the board are of carbon conductive types, and can be easly damaged if handled carelessley. More over there is a lock for each end of these wires, that only an experienced one can take it out and reinsert in to safely. The fault is loose contact itself.
2 Related Answers
Anonymous
  • Posted on Feb 05, 2010
SOURCE: I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Jul 16, 2008
SOURCE: lost half of picture
This can be on the matrix drive board, or the display assembly itself. It is possible to also have a defect in the address decoding area that will cause this.
The procedure is to swap out the suspect boards to determine where the fault is, leave the working boards in the set, and then follow up any necessary calibrations that are necessary.
Jerry G.
1helpful
IR board location
Hey Tony,
The IR board will be on the inside of either the bottom center, left, or right of the front bezel.
2answers
Left half of screen dimmer than right
same issue with my 47le5900 - I have fixed it... if I look through the back panel I can see a circuit board on the right... coming out of this at the top are two flat data cables, each about 1 1/2 inches wide, one is labeled (L) the other (R), it seems the (R) one was a little loose, so I pressed it downwards with a small screwdriver, problem solved.
LG 50PK750 turns off as soon as I turn on
This issue is a common, but hardly talked about from LG. Your tv is probably 1 or 2 months out of warranty, and now you're hearing a series of clicks. ... If you have the courage to open the back cover of your tv, and you do "NOT" see any bad (bulging ) capacitors on the power supply, then it could be the voltage regulator. After weeks of fighting with LG to replace my tv, i decided to fix it myself. i'm proud to announce that my 50PK540 is now working. want proof? Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis several 50PK750 models, Some clients have send me their broken power supply board, so I can do the repairs. Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at [email protected] if you have any questions.and watch the video: part 1 & 2
Repair kit on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200849231403
Youtube video PART 1 & 2
http://www.youtube.com/watch?v=I9wF0OLyV0k
http://www.youtube.com/watch?v=vHrv5XaDULI
We have half a screen when we turn on TV
Your TV's primary control board may have gone bad and when the TV heats up to a certain tempurature and then it goes back to normal i suggest a new tv but you can order new parts and replace it yourself, if you need parts I can get a list of parts that may fix the TV
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
2answers
While watching tv it suddenly cut off,now it is making a clicking sound and will not turn back on
If you remove the back you will find a couple of electrolytic caps that need replace, and/or just replace the power supply. That should take care of your problem.
When i inplug my lg 50pk750 plasma to power sorce turn on and before show the picture it turn off.
This issue is a common, but hardly talked about from LG. Your tv is probably 1 or 2 months out of warranty, and now you're hearing a series of clicks. After weeks of fighting with LG to replace my tv, i decided to fix it myself. i'm proud to announce that my 50PK540 is now working. want proof? Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis several 50PK750 models, Some clients have send me their broken power supply board, so I can do the repairs. Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at [email protected] if you have any question.and watch the video:
http://www.viewbix.com/v/LG-Repair-KIT-now-available-on-Ebay/8ec4bea5-1d91-4d23-8180-7e5214e6c8f6
2answers
LG W2243S - Keeps going into Safe Mode
Check your power source, maybe it is not getting enough power or getting to much power. Its happened to my amps before.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
