Question about Thomson 21DC320 21" TV
No Video I have a 21 inch tv and when i use the AV like a dvd the audio is on and the picture nothing , can some one help me pls ?
    Champion:
  • 252 Answers
Try to change cord of video and the audio maybe the cord had a problem
Posted on Nov 16, 2008
I DON'T KNOW WHERE TO PLUG MY DVD CABLE IN TO MY KV SONY TRINITRON- THERE DOESN'T SEEM TO BE ANY PLUGHOLES
Hello
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I have a JVC AV-27D501 TV, I'm trying to connect a DVD player to the TV but not able to get the Video or Audio. My DVD player has Video Out (Yellow) and Audio out (white & red). Connected the AV cables...
I'm assuming the cable was plugged correctly - the colors matched. VIDEO 3 is for the front connectors so it should have worked . Since it hasn't then one of the three parts in this setup (tv, player, cable) is defective. To find out which you must do some simple tests:
1. replace the cable and try again.
2. take your player and connect it to a surely functional tv - if it doesn't work in there then it's defective.
3. get another player that is surely functional and connect it to your tv - if it doesn't work then the AV switching IC from your tv (soldered on the mainboard) is defective and it will have to be replaced. Call a repairman, there is nothing more you can do.
Nov 06, 2010 | JVC AV-27D501 TV
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
DVD is playing but you don't see it on the tv . Do I have to put TV on a certain channel while playing DVD?
pls check dvd AV cabel .
if ok
then
playing dvd first and see dvd back side pin .
VIDEO OUT
after see on your dvd remot cantrol and check interface key if yes then use key to set display on screen S-VIDEO and see the picture is normal .
if not then.....
pls see the dvd back side
GY /BU /RV three pin
pls video out pin is plugge out and concting with step by step in all three pin
if sum picture on screen pls. canect and hold .
after that use dvd remot cantrol and selact SETUP key to on and see and open video interface menu pls set video system is select S_video.
after that reconact video pin is VIDEO_OUT and see picture is normal .
Oct 08, 2009 | Panasonic DMR-E75V DVD Player/VCR
Getting video form dav-dx to older sanyo TV with an S-video jack
Check what is input number of S-Video in TV and select that av input with TV remote.
Jan 23, 2009 | Sony Dream System DAVDX155 Theater System
INSIGNIA TV FLAT PANEL (not LCD) cant play PS3
Check to make sure it is on either the AV 1 or AV 2 channel
Nov 25, 2008 | Televison & Video
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Can't find my user manual and need help hooking it up
First check Color code
Yellow is for Video Red is for Audio Right Speaker White is for Left Speak.
Do you see rear pannel of the DVD there is Socket
Connect Yellow Cable to Video Out on the Dvd other end of the Cable to Video In on TV.
Connect Red Cable to Audio Out on the DVD other end of the cable to Audio In on TV.
Connect White Cable to Audio Out on the DVD other end of the Cable to Audio In on TV.
Turn on TV as well as DVD Player.
ON tv remote do you seee buttons as TV/AV. AV, Aux, Video, Input, or Game, Pree any one of these Buttons, You should be able to get Picture.
Jul 30, 2007 | Curtis CMD5000 DVD Player
Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
May 23, 2007 | GE 27GT622 27" TV
Thomson 21DC320 21" TV Logo
114 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
