LG DLEX5101W won't heat. I have already checked and reset the circuit breaker and performed a flow test to check for blockage in the duct
Well it could be 2 things The either heating element has gone out or a thermostat is bad Parts F 140 and F 130 in the link below.Testing these with a continuity tester will see which one it is. Please rate my solution and leave testimonial this is how i earn my achievements thanks in advance. So to sum it up you may need part F130-F140- or F110 is the heater coil.
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Dryer-Parts/Model-DLEX5101W/3204/0151200/F1010046/00004?blt=06&prst=0&shdMod=DLEX5101W
Also heating element is in the link below Part number F 110 for heater
how to I determine the cut-off temp of the hi-limite thermostat
The High temp switch does not have to be removed to test it if you can get to it. You need to find an Ohm meter with continuity test on it it looks like 2 arrows facing each other on the control panel of it. The ones with sound are best for this test. But always remember to (Un Plug) before any testing in any electronic device.
Ok after setting the sound continuity to buzz when the Ohm leads touch the red and black leads will now sound a buzzing sound or steady beep until removed.
To test the limit switch you touch it to both sides of the limit switch at the same time you want to hear this sound if you do not it is bad simple as that and in the same setting you want to test all of them and your heating element the same way checking both ends of it. Remember to rate and leave testimonial for my services this is how i earn my accomplishments Thanks in advance.
SOURCE: where is circuit breaker in a LG DLE9577WM dryer
it could be the thermostat it could be a burned heat element if electric verify gas or electric
SOURCE: whirlpool dryer works fine but is not heating
If this is a gas unit the igniter - may be cracked or burned out!
Electric the coil or element is burned out
SOURCE: Dryer not generating heat and drying clothes...
Dear customer,
We recommend you to do the following checks when your dryer isnt generating heat..
Thank you.
SOURCE: LG DLG2532W Gas dryer problem
dryer working and heating properly, when cycle complete all my clothes smell like gas though. Any suggestion
SOURCE: MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
hermal Fuse
Another possible cause for a dryer not
heating up could be attributed to a faulty thermal fuse. Once a dryer's
thermal fuse has blown, it is no longer of any use. If your dryer's fuse
is blown, you will have to replace it. Open up your dryer's cabinet and
locate its thermal fuse so that you can test it.
Thermostat
If any of your dryer's thermostats have
become defective, they could be the reason that your dryer is not
heating. Open up your dryer's cabinet and test each of your dryer's
thermostats. If any are faulty, replace them.
Timer motor
A defective timer motor could also
cause your dryer to not heat up. Test your dryer's timer motor. If it is
no longer functioning as it should, replace either the entire motor
assembly, or just its motor.
How do I determine the cut off temperature of the hi-limit theromostat ?
