Cooler CPU Fan
I have one motherboard Foxconn G31MV-K and when tying the computer, show this message: ''This motherboard only supports low power energy-saving CPU's (less than 65 W).
Could anybody help myself?
Thanks
  • brambila Nov 17, 2008
    Hi hokuwho,
    I don't have access to the list. Has an other alternative?
    Regards.
    Brambila.
    Sergeant:
  • 306 Answers
Here is a list of the compatible CPUs. Is yours on the list? Did it come with the CPU installed? Steve Medley C:\Users\Stephen J. Medley\Documents\Downloads\200811030909521886G31MV-CPU-A85.mht
Posted on Nov 16, 2008
  • Stephen Medley
    Stephen Medley Nov 17, 2008
    Yes, tell me what cpu you have and I will see if it is on the list. Just curious, why can't you access the list? It is on the Internet as you now are.
Overheat errorhow to fix the problemi have Foxconn n15235 G41MD-Vwith pentium CPU
Download and run speed fan and monitor your temperatures to make sure there are no other possible issues. If the computer is unable to turn on, remove the power cable from the power supply on the back of the computer, open the tower, and re-seat all connections including the CPU. I would imagine since the motherboard is a socket 775 you will more than likely you will need to re-apply thermal paste (http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007) to the heat sink or you need a new heat sink all together. Since your motherboard is a socket 775, here are a few heatsink/CPU cooler upgrades that may help the problem:
10$ and shorter overall profile since the case size is unknown
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186070
25$ and a bit taller, but I successfully used this heatsink for 7 years before it gave up.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Jan 16, 2014 | Computers & Internet
Will a GeForce GTX 550 Ti fit into a G31MV-K Motherboard?
Hi nproudfoot,
Your Geforce card is a PCI-E 2.0 x16 and your Foxconn board has a PCI-E card slot bus. So yes, your Geforce display card will fit into the motherboard.
Best wishes,
Graemevm
Jan 11, 2012 | Foxconn G31MV-K Motherboard
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
Foxconn G31MV-K MOB. Of late stopped logging on to internet. Tray icon says limited or no connectivity.Status window shows 142 bytes upload but no download. tried reloading drivers no luck. whazzup.
In order to assist you I need to know exactly how you connect to the internet and who your service provider is. The problem is almost certainly with your ISP (service provider) and not with your PC.
Best wishes,
Graemevm
Aug 31, 2010 | Foxconn G31MV-K Motherboard
Can a Foxconn G31MV-K work with a Intel Pentium Dual Core 2M/800
Yes. This motherboard can work with the Intel Pentium Dual Core 2M/800 E5200 (2.5G) processor.
Below is a link to a page that lists the specs for this motherboard:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000376
Jul 26, 2009 | Foxconn Computers & Internet
Foxconn CPU fan making noise
It sounds like the fan bearing is shot, I'd recomend not using the computer until fan is replaced.
yes it is possible to replace the fan, i would recomend that you replace it with an aftermarket cooler. all you need is what kind of CPU you have, then find out what kind of socket it is, from there you can find the cooler you would like.
Jan 27, 2009 | Foxconn CPU Cooler Fan CPU Fan
Could a faulty fan cause my pc not to switch on
Normally the computer will still come on even if the fan is not there but then will sometime display cpu fan warning and then sometimes turn off depending on motherboard and so on but unless the fan wires are shorted out or something this is most likely not the case
It sounds like your power supply has gone bad
Do you hear any type of winning sound or like a discharge sound that is barely noticeable when you turn it on? You would probably almost have to put your ear right next to it to hear it or listen carefully when you press power because that sound is one of the capacitors in the power supply that has gone bad and the power supply would need to be replaced
Do you have another power supply you can use to see if it works with a different one?
Nov 25, 2008 | Intel Foxconn: Foxconn CPU Cooler For P4...
Computers & Internet Logo
639 people viewed this question
David Payne
David Payne
