Question about Directed 3124 Car Subwoofer
Box type, dimensions And wireing for a 2 12''4Ohm duel voice coil
Need box info and wireing diagram also when i hook both subs to 2000 watt amp it forces protection in the amp
  • magick214 Nov 16, 2008
    help please
    Problem Solver:
  • 8 Answers
Http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html this website will help you out with wiring but as far as box info what kind of box do you have and if its going on protect mode you need to turn your system down bkz your running to much juice. either that or you have a short somewhere
Posted on Jul 25, 2010
I have 2 duel 12' 2ohm sub's and a blackmore bac m-50 2000 watt 4ohm amp and was wondering how to wire. Thanks!
boz word of caution is to be heeded. with 2x2 ohms per speaker, you can only use one, with the voice coils ran in series to increase the resistance to 4 ohm . take a single driver, and use the series wiring on with both of the 2 ohm voice coils.
wire positive from the amp into positive of one voice coil, then the negative of that voice coil to the positive of the second voice coil 9bridging with 6 gauge or so, as was also mentioned by a previous user), then lead the negative of the second voice coil back to the amp's negative terminal.
Jun 01, 2015 | Car Audio & Video
On a lanzar 535n 5 channel 3200 watt amp what is the best way to hook up 2 lanzar max 12 inch duel voice coil subwoofers
If your amp allows it hook the the sub's to the first two channels but bridge it and only run it on 2ohms so you don't blow your sub's
May 29, 2015 | Lanzar Car Audio & Video
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
There are 4 connectors on each side of the speaker, how do i wire it so i can put the sub in the box so i can connect it to my amp?
There are 4 connectors on each side of the Problem with the Lanzar 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker. how do i wire it so i can put the sub in the box so i can connect it to my amp?
Dec 24, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Need help wiring A 15'' alpine type r duel voice coil to a 1400 watt Crunch amp.If this amp is even compatable, When i hooked it up my self the sub made the surge light on my amp come on after like 10min...
That would suggest a short between the pos and neg on the amp, it shouldn't get hot, if the surge light came on it must be a dead short, if you've got a multi-meter check the resistance on the voice coil make sure its not high (like above 1Mohm) or below 4 ohms, Normally the sub will have an impedance of 4 ohms. Have you got another speaker you could test on the amp, any should do, does it get hot with nothing connected? (that would suggest a fault on the amp) is it new?
Mar 26, 2010 | Alpine Car Audio & Video
Speaker or amp?
your running too low impedence, and yes its cuz of your sub wiring. How to wire it depends if its 2ohm dual voice coil, or 4ohm dual voice coil, so i'll explain both. O.K. first of all i hope its 4 ohm so you can get max power from your sub. If it is 4 ohm dual voice coil connect + to +, and - to - on your speaker, then to connect it to your amp, splice a wire into the wire running from + to + and connect it to your amp's + terminal. Do the same with your - wire. If its a 2 ohm dual voice coil, connect the + from one set of terminals on the speaker, to the - on the other terminal. Then to connect it to the amp, plug a wire from the open + terminal on the speaker and connect it to the + plug on the amp, and do, connect the empty - to the - on the amp. Good luck and if you have any questions don't hesitate to ask...
Sep 20, 2009 | Car Audio & Video
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Subs
2x12 in sub each duel voice coil can iether wire to 1 or 4 ohms. im guessing you have everything wired up in series (1 ohm) and aer probably burning out the amp.
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DVC%5F4%2Dohm%5Fmono
Feb 25, 2008 | Car Audio & Video
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Directed 3124 Car Subwoofer Logo
102 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
