Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Date and time error
Sir, Every time when I start my PC the messege error displays that 'set your PC date time through control panel. After doing this this error displays again.
I also change my CMOs battery.
PLs help me out from this error
    Problem Solver:
  • 5 Answers
Hi ya, yeah, my first suggestion would have been to change the CMOS battery, and if you are sure that the one you replaced is new and well charged, then the next thing I would be checking is the time in the system BIOS (rather than using Windows). If you know how to access the BIOS then try changing the time there and then reboot. Power off your computer and turn it off at the wall for a minute or two and then turn everything on again. If your date and time are still correct then you've no more problem (hopefully!). If however, your date and time still change afterwards upon leaving Windows, it is -possible- that there is a 3rd party application on your system that is changing your time/date. If you want to count this possibility out, then take a look at any of the icons in the bottom right of your windows toolbar (beside the clock) to see if there are any new/weird applications running that have anything to do with time or date (some applications adjust your date and time based on your locale and a server on the internet to save you the trouble of ever wondering if your time is right etc.)
Hope this helps point you in the right direction.
Posted on Nov 16, 2008
How do I fix my PC bios problem: After shutting down the PC, the time & date of the PC is wrong , what can I do?
Replace the battery on your motherboard.
I used to have that issue. Replacing the battery should fix that.
Apr 14, 2015 | Computers & Internet
Display problem
this may or may not help but it has worked for me many times in the past in a tight jam. good luck.
Apr 07, 2014 | HP EliteBook 2530p Notebook
How do I set the date?
Follow the instructions below to set date and time on your printer.
  1. On the product control panel, press Setup (c01715732.gif ).
  2. Press the Left (c01185108.jpg ) or Right (c01185072.jpg ) Arrow button to select Basic Setting , and then press OK .
  3. Press the Left (c01185108.jpg ) or Right (c01185072.jpg ) Arrow button to select Date and Time , and then press OK .
  4. After Enter date appears on the control panel display, use the keypad on the control panel to type the date in the correct two-digit format, MM-DD-YY (01-01-10). After entering the date, press OK .
  5. After Enter time appears on the control panel display, use the keypad on the control panel to type the time in the correct two-digit format, HH:MM (10:15), and then press the Right (c01185072.jpg ) Arrow button to switch between AM and PM . After entering the time, press OK .
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do i set the time and date
Hi
Note If you press Start Fax Color but the sender sent the fax in black and
white, the HP all-in-one prints the fax in black and white.
Set the date and time
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
All The Best: Pineworks
Jan 28, 2010 | HP OfficeJet 6210 All-In-One InkJet...
System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
Dec 21, 2009 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Setting date and time on HP office jet J4580
    press OK .
    press OK .
  4. After Enter
    date
  5. After Enter
    time
Aug 21, 2008 | HP Office Equipment & Supplies
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
I need to set day and date display on my computer
I assume you mean date/time right click with the mouse on the time at bottom right hand corner a list will appear left click with mouse on adjust date\time a screen will appear and you can adjust time and date on that screen.
Another way to access this control is left click start button highlight control panel double left click with mouse and double left click on date/time option
Apr 27, 2008 | Computers & Internet
My computer went back to older clock date as 1610
try starting your computer in safe mode and see if you can do anything productive there, like scanning for viruses or spyware. also check if you can do the following:
CTRL+ALT+DEL (open task manager)
goto Start>Run>Regedit (open registry editor)
goto Start>Control Panel>Display>Properties (change display settings)
right click on clock at tray and change the current time to correct settings
if you cannot do any of these activities, then your computer may probably been compromised by a virus or malware.
Jan 02, 2008 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
