Question about Novelty Elvis Phone (w-elvis)
Elvis Phone Have and Elvis phone I got in Vegas. I can't use it as when I hand up and put the reciever back into the base it hang up the little black button that hangs up the phone won't retract unless I sitt something heavy on top of it! Hope you understand what I'm saying (it's hard to explain. Can I buy a new reciever? Or can I get it fixed? I have the black based one! Looking forward to your reply as I Love the phone so much and love useing it. Cheers Louise Bell
  • heartbreak May 27, 2008
    hi i have got the elvis telemania novelty phone but i when someone calls me it sounds very muffled ?
    someone said the speaker may be broke ?
    any ideas or do you know were i can get a handset replacement?
    loraine
    Novelist:
  • 201 Answers
So the handset is not heavy enough to hang up the phone? This is a new development? The spring for the hookswitch may have gotten jammed in the wrong position causing more spring tension. It sounds like a fairly easy fix. You may find a local TV, VCR, etc.. repair business willing to look at it.
Posted on Jul 05, 2007
I have got sony ericsson k310i, from last two weeks my mobile is getting hanged everytime. when i lift call,it is getting hanged after 30sec.whenever i recieve any message i am getting the same problem....
The problem is in two ways is either you have a higher memory card n your phone that will always drag the functionality of your backward, or your phone is exposed to virus through your bluetooth . The best solution is for you to check your memory card and minimize the memory to a lower memory and if it keep on slowing then you will flash the phone ,i.e you will flash the phone from a software base system and then all will be ok.
May 17, 2010 | Sony Ericsson K310i Cellular Phone
Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
Jul 27, 2009 | Uniden TCX905 Cordless Accessory Handset...
I cant switch on my p990i phone.
Try power cycling the phone:
1. Remove the battery and leave it out for 5 to 10 minutes.
2. Put the battery back and turn the phone ON.
If you get the same problem, contact the manufacturer for possible firmware upgrade or repair.
Have a great day!
Jul 26, 2009 | Sony Ericsson P990i Smartphone
Phone hanging
hi thanks for using fixya!!
Try to turn off the power of your Nokia 6230i, then remove the battery. Then try to install it back again. Now, observe, turn on your phone. If still the same error, I suggest you bring your phone to a Nokia Care Center in your area.
If you need further assistance, let me know!
Jun 01, 2009 | Nokia 6230i Cellular Phone
Uniden 1725 no dial tone
I had the same problem as long as they are plugged in correctly and you put the #2 handset into the #1 cradle to register it to your base then try hanging the phone up several times. These are expandable phones so that I believe you can keep adding other handsets. So sometimes they think you have a few more handsets than you really have so when you hang up it may not know what handset you are hanging up #1 #2 or #3 #4 etc. So I had to keep hanging them up until it finally hung up. Then I had to re install them so it knew I only had 2 hand sets. So then you start from the beginning, like when you took it from the packaging. I hate these phones. I ended up replacing them with different ones. Plus I always keep a rotery phone laying around put away because during a power outage you still can plug in an old dial phone and it will work! Nothing like old technology.
Feb 15, 2009 | Uniden 5.8GHz Dual Cordless Phone
Wall mounted ge phone
Problem solved. The little black square was supposed to be put back upside down...This allowed the hand held piece to hang on.
thanks
Aug 05, 2008 | GE 29263GE2 Corded Phone
KX-TG6700 Freeze
Remove the base by taking out the five screws. Look for the ribbon cable on the left hand side. On each side of the cable is a little brown nub, pull away from the circuit board to release the tension. Pull the ribbon cable out, this will reset the circuit board. Put the ribbon cable back in and push the nubs towards the circuit board. This will add tension to the connection. Put the base back together using the 5 screws. Plug in your phone and you should be set.
Austin Ron
Jun 07, 2008 | Panasonic KX-TG6700 Cordless Phone
Phones won't pick up calls...say connecting
HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
Nov 20, 2007 | Uniden TRU9380-2 Twin Phone
Move closer to base
Either the phone is not registered to the base unit or the RF module is broken. It could be a bad battery but unlikely unless very old or you have not charged it. You should check the manual for registering the phone to the base unit.
Sep 07, 2007 | Panasonic KX-TG2584 Cordless Phone
Novelty Elvis Phone (w-elvis) Logo
168 people viewed this question
Top Novelty Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Novelty Lands Phone Expert? Answer questions, earn points and help others
