Question about Hitachi Televison & Video
Hitachi 32LD6600 defaulting to ext-5 input, cannot change input from remote or set - non resposnive
    Problem Solver:
  • 5 Answers
you have to get your tv into "hotell" mode:
1 meny then type 1,3,2,5 and the hotel meny show...set it on and to start on ext5....close with meny...turn tv off and then on and your problem is solved
Posted on Aug 18, 2010
Wharfedale tv settings
By default, the TV stores memory of last settings in its memory ic, when you switch off. By modifying the input devices, you have increased the number of settings to be stored, which might be beyond its capacity to store and it switches to default settings. Try resetting to the desired input and locking the settings.
Aug 05, 2012 | Televison & Video
Inputs will not change with remote with my Harmont reomte
It will be difficult to match any other universal remote with this model Hitachi set. You have to get the original remote control to select all the functions with this TV. If your original remote control doesn't work at all, just buy a new one. You can get it from the authorised service center for Hitachi at your town. OK.
Nov 04, 2011 | Hitachi 55HDS69 55 in. Plasma Television
I have a hitachi 43uwx10b and i don't have the original remote. neither the universal remote i bought nor the remote that my cable company provided seems able to change the input. all these remotes do is...
Yes, almost ANY hitachi remote made in the last ten years will work.
The original will have a CLU-5722-TSI marked on the front. Lots of them on Ebay and other sites.
Google the model number with the word remote after it and see how many there are.
Lots of universal remotes will be missing functions only on the original remote. That remote will operate all the projection, LCD, PLASMA, and regular sets made by Hitachi for at least the last 15 years.
I know, it works on my 1991 Hitachi rear projection set perfectly.
Let me know if you have questions---avoid universal remotes like the plague.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Sep 18, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi Plasma will not remember what input to watch tv on
Dec 20, 2008 | Hitachi 42HDF52 Television
Hitchi 42pd8600
If you have to keep on changing the settings and the tv will not store them then there is a fault with the internal memory of the tv. If you can return the tv or call out a competant technician. Hope this helps.
Sep 02, 2008 | Hitachi 42HDS69 42 in. Plasma Television
No Blue Hitachi 50v500
Yes, find a good signal on ch 3 either from a vcr or straight cable. If you change to another input you will adjust set for that input or for that format. Make sure once again that you don't change any settings except the one in question...memory init. You may have to push arrow twice to save changes but I'll check on that. If all else fails you may need light engine.
Jun 10, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Accessing External Inputs Settings
you have to use the remote control for the tv not the dvr.
the dvr control likely cannot control the tv inputs programming unless you can program the correct code. and most new lcd panels don't have the correct codes for existing remotes
access using ext on the tv remote.
you may have to go into the menu and tell the tv what the ext is set to ie.. a channel or a input.
Feb 18, 2008 | Sony BRAVIA KDL-40V3000 Television
Problems with Ext ins staying on
Check your user manual. Many Denon receivers have a reset function that returns every thing to the default factory settings. If you still can't change the input, professional service will be required.
Sep 18, 2007 | Denon AVR-1507 Receiver
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Locked ext inputs
I'll give you the master reset, with set on, and from the remote hit Menu-1-2-7-0 this will bring up the Intilize screen and the word Initlize should be highlighted, if it is hit enter on the remote, this is the factory default settings so now if the set ask for a parental code it will be 0000
Nov 06, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
363 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
