Question about Toshiba 36A42 36" TV
Brightness on my tv quit workin
I have a 36a42 Toshiba tv the brightness quit working and the screen is to dark...cant lighten the screen with the controls...I need ta know what part in the tv works the brightness so i can change it out . HELP!
  • Dusty Privette
    Dusty Privette Nov 17, 2008
    Dude you rock man!!!!!!!! thanks for the tip! worked perfectly!!
  • Anonymous Mar 27, 2014
    remote control won't run the Tv
    Champion:
  • 252 Answers
Open your tv.At the back you see a plyback,it is big parts of tv with a wire attached to the picture tube,that is plyback At the buttom you wiil see a two knob, the lower knob is for the screen and the upper knob is for the focus.Adjust the lower knob or screen .
Posted on Nov 16, 2008
How do i get my screen to lighten up it to dark
Have you tried using the F2 button?
Else go to system settings > displays, there you can adjust brightness as well.
Also you can switch off the auto brightness there. 25262036-egkukr40z00e2y5uxj02hrxw-1-0.png
Oct 30, 2014 | Apple Computers & Internet
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Oct 24, 2014 | JVC Televison & Video
How do i lighten the screen ...it is so dark i can hardly read the print
If your screen is that dark when it boots up, you may have lost the inverter that supplies the increased voltage to run the screens backlight. The commands for the lightening and darkening the screen are as follows.....
<Fn> and up-arrow key Increases brightness
<Fn> and down-arrow key Decreases brightness
May 24, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 36A42 36'' T.V.
A common cause is a failure in the one of the scan amplifiers or on the high voltage section. It is also possible to have a power supply fault that will give this error message.
Jerry G.
Dec 14, 2008 | Toshiba 36A42 36" TV
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
Picture way too dark
Good day,
There is an adjustment on the rear portion of your units flyback. It controls the screen brightness. Check out on this.
chris
Nov 28, 2007 | Toshiba 36A40 36" TV
Toshiba 36A42 TV. Dim Picture
Check the "screen" control on the flyback (lower knob) its easy to hit moving a board around. Try to adjust back to its original setting. Look for where the dust is, it should be on top. Or any marks might help. Other wise adjust slowly, back off if any retrace lines appear, with user settings at there normal settings.
Oct 27, 2007 | Toshiba 27AF42 27" TV
Toshiba 36A42 36" TV Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
