Question about Brother FAX-1030e Plain Paper Thermal transfer
Brother Fax-1030. Not worked since power failure. Only prints power failure report saying 'The electricity failed. The Following data was lost ? Transmission Memory'. Then stops and the LCD screen displays 'Check Paper' and when you reset the paper supply it then prints another 'power failure report' and then goes back to 'check paper'. When a fax did try to come in the LCD screen displayed 'memory full' but now it has gone back to 'check paper'!!!!!!! How can I reset the transmssion memory??????? Thanks Sue
    Master:
  • Brother Master
  • 304 Answers
Hello Sue!
In Brother Fax-1030 the stored documents will be saved for up to 6 hours in the event of a power failure
Please check "Troubleshooting" in the manual. I hope it will help.
http://manualsbrain.com/en/manuals/1194808/?page=78
Posted on May 19, 2017
5 Suggested Answers
SOURCE:
leroyal
  • 2120 Answers
SOURCE: need to prin faxes in memory 2820 brother
Try unplugging the power cord.
Posted on Sep 20, 2008
leroyal
  • 2120 Answers
SOURCE: check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Posted on Nov 26, 2008
KingDWS
  • 1606 Answers
SOURCE: No manual to "Brother Super G3 336kbps IntelliFax-2920"
It is telling you the fuser unit needs replacement. Thats the heater that fuses the toner particles to the paper by heating them. If it cannot reach the correct tempurature the toner comes right off the paper.
So you will need to order a fuser wire kit to fix that error. That can be fairly expensive on a brother. I believe somewhere around $150 and up.
I can at least help you get a replacement manual. This link takes you to the downloads for your printer and you can then download the various manuals.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_top.html?reg=us&c=us&lang=en&prod=fax2920_us
Posted on May 13, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: brother 8360p has faxes in memory but will not
I have seen a few Brother faxes do this. I fixed them by turning off the power, holding down the clear/stop button and keep holding it down while you turn the power back on. Keep holding it for a few seconds then release. This will clear what ever is in the memory that is locking up the memory print. Note: you will lose any received faxes in memory by using this procedure.
This may help you restore your fax to a operation condition.
Good Luck and Thank You for using Fixya.
Posted on Aug 19, 2010
Dcp 7055 brother printer in error - print unable ec
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Note
    In order to transfer data from your fax machine to another, you must have the station ID programmed in your fax machine.
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set.
  4. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Start.
Step2: Verify and Transfer faxes in memory
Step3: Reset the machine After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, do the following based on your country:
<USA>If your unit is still within warranty, try to locate a Brother Authorized Service Center in your area or google to obtain contact information for the appropriate Brother Customer Service Center.
If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
Aug 04, 2013 | Office Equipment & Supplies
When i switchon my machiene an error occured Print Unable 52 please get me out of here regards
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
    Open the top cover and remove any foreign obstacles from inside the fax machine. If you see jammed paper or another item inside this area, gently pull it out and then close the top cover securely.
  2. Press the up or down navigation key until MISCELLANEOUS appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until DATA TRANSFER appears on the LCD. Then press Menu/Set.
  4. Press the up or down navigation key until REPORT TRANS. appears on the LCD. Then press Menu/Set.
  5. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Fax Start.
  4. Press the up or down navigation key until FAX TRANSFER appears on the LCD. Then press Menu/Set.
  5. If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3.
    If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Fax Start.
If the message continues to appear on the LCD, please contact Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 19, 2010 | Brother Multi-Function Center MFC-240C...
Says: Unable to Clean Consult owners manual
Dec 16, 2010 | Office Equipment & Supplies
Unable to print 5A
Dec 15, 2010 | Brother HL-4040CN Laser Printer
HOW CAN I STOP THE MACHINE FROM PRINTING AN ERROR REPORT AND WASTING A PAGE OF RIBBON
The brother fax machine will always print out a transmission report when there is a failure to send a fax.
There is no way to turn this feature off.
The closest option to this is turning transmission reports off, but this will still print out a message when the fax does not go through properly.
Mar 25, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I faxed something last week and lost the transmisson verification report, can it be re-printed? does my fax keep it in memory?
It's possible to print a Fax Activity report which would show both incoming and outgoing fax activity. To do this, do the following:
  1. Press Reports
  2. Use arrow keys < > to select 3. Fax Activity
  3. Press Set
If Fax Activity hasn't been set up, do the following:
Setting the Fax Activity Report Interval
You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF, you can print the report by following the Steps in the next page.
  1. Press Menu, 2, 4, 2.
  2. Press or to choose an interval,
    and then press Set.
    (If you choose 7 days, the LCD prompts you to choose a day at which to begin
    the 7-day countdown.)
I hope this enables you to recover your transmission report. Please post back with any questions or just to rate the solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
Brother FAX-1030e Plain Paper Thermal transfer Logo
111 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
