Question about Toshiba W522 VHS VCR
Lost remote on toshiba w528
I lost remote on a toshiba w528. Can I still select the input source like line 1 or line 2 w/o a remote??
  • jfin79 Dec 28, 2008
    I the same problemcant select l1 or l2 without remote tried universal no success
  • Anonymous Mar 13, 2009
    SAme problem w/w522
  • 22 Answers
You can select those to record with out the remote by setting the record timer to record. For example, if you want to record from one of those input channels on Friday 1 January 2009 at 9:00 to 11:00, it will allow you to choose that as an input channel in that program menu. If not, you will want to buy a replacement remote. VC-522 is no longer available, but VC-617 and other models are.
Posted on Dec 27, 2009
My Toshiba TV shows blue screen an no signal
The TV may not be on the correct source or input.
You can change the source by pressing the source or input on the TV or remote. VIDEO 1, 2,3. COMPONENT 1,2 OR HDMI 1 etc..
www.aaatvservice.com
Aug 15, 2014 | Televison & Video
How to switch tv over to play games on wii
press menu button and look for source or input and manually do it onscreen, different buttons scroll through choices, enter button selects choices
Aug 20, 2012 | Toshiba 30HF66 30" TV
I unplugged my television, and plugged it back in, but the TV will not turn on now.
What probably happened is the Input mode was reset. Using the TV remote (not the cable or dish remote) look for a Input button or Source button. With the TV on (the screen may be black but you should see a small power light) use the Input or Source button on the remote to select the TV's source (ie cable, component, HDMI etc).
Jan 05, 2012 | Toshiba 57H83 TV
Is there a way to operate the aux line 1 and 2 without a remote
Usually, if you push the Channel button beyond the number of channels you have, it will proceed through the Active Inputs, or Aux 1 and 2. If not, you may want to check if your TV has a Source or Input button on it. Else, check the Menu for Input selections.
Last but not least, get a remote if none of the above help.
Jul 02, 2011 | Memorex Televison & Video
I have a Toshiba W528 VCR and am trying to hook up a Wii in the front panel Line 2 jacks. How do you switch the connnection to the Line 2 jacks without a remote?
With the up and down channel selector buttons. You will have to keep pressing either button till it shows AV (something IE 1 or 2 etc). Depending what it says on the front panel for the socket.
Recommend a universal remote if you can't get a new one.
Feb 06, 2011 | Toshiba W522 VHS VCR
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I can't hook up my dvd player to my quasar model v v 1309 because we don't have a remote and can't change the input. The screen is blue and the channels change.
You should be able to change the input mode by changing the channel up or down past the regular channels (so channel down 3, 2, 1 > Line > 125 (if cable source) or 69 (TV source).
A replacement remote can be gotten from remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=VV-1309&uuid=12897739886740 . With the remote, press Action and then enter the menu then choose Input Select and then choose Tuner or Line.
I hope this helps.
Nov 14, 2010 | Quasar VV1309 13 in. Combo
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Toshiba W522 VHS VCR Logo
788 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
