SOURCE: HP pavilion desktop only has built in RJ45 connector--problem?
If you have built in 10/100 RJ45 then any network connection is possible.
One to one, you can connect to any built in 10/100 RJ45 equipped computer with a 'cross-over' network cable.
More commonly you can connect to a 'router' which allows a number of computers to connect to each other and to the internet . Use a search engine to find net setup on the 'web.
This is a very large subject so you need to decide what you want to do first!
See
http://www.computerhope.com/issues/ch000469.htm#04
or
http://compnetworking.about.com/cs/lanvlanwan/g/bldef_lan.htm
or even
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
SOURCE: Dvd does not work all of the time.
If it does not read any CD/DVD inserted into it, then run Microsoft Fix which is provided in the web link below. This will delete the drive registry limits.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00678214&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3224052&lang=en
If issue persists then perform the remaining steps in the above web link.
For Troubleshooting playback problems with CDs, DVDs, and VCDs, refer the below web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00814995&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3224052&lang=en
SOURCE: I have pc Hp compaq
Hello, was the sound working before, i would like to know
1. Your sound card might be disabled from the bios. Restart your computer and quickly press F2, F10 or Delete button to get into the bios to check.
2. Un-install your sound card driver completely and then re-install
3. Your sound may be disabled from within windows, check for the speaker icon on your taskbar and if the slider works.
4. Another hardware on your computer is conflicting with your sound card. Have you installed any recent hardware or software? if so remove them and see if it solves the problem
Why would you want to remove the faceplate?
If you have a dvd or cd stuck in the drive straighten out a gem clip (paper clip) and stick it into the hole that is on the faceplate (drive drawer that holds the cd or dvd) and push it while you press the eject button.
Testimonial: "miltc484: Thank you so much! I was afraid I was going to break it doing that, ha."
