Hi I am trying to connect my sd box via my video player or so it works any where, I dont know where the plugs should go, been trying for two hours. I know it works as my partner had it going earler, but sook went to bed, I need help please
I fixed this myself, I pluged the av cord directly from the sd box into the video input, the scart into the tv dvd, the rca into the video from the sd box then from the video rca to the tv rca, works a treat
Posted on Nov 17, 2008
My tv is not 'seeing' any of the hdmi devices plugged into it.
surge protectors do not work very well. They dont really stop mildly high voltages. If you can plug the Directv receiver into another TV and it works, then you have a bad digital board in your TV.
Aug 15, 2015 | Toshiba Televison & Video
I can't find any channels at JVC LCD TV
Not knowing the model I will make some suggestions: If have a DVD player and it works via the rear audio/video inputs try connection of your set via the rear jacks like the DVD uses.
How are you hooked up? cable? cable box? Sat? what?
If no channels found it may be no signal is reaching the set or the tuner in the set is bad--lots of reasons with same result.
If for example have a cable box with audio/video outputs connect instead of to the coax fitting on the set to rear jacks--go to that input and change channels with box---by pass whatever this issue is.
Apr 30, 2012 | JVC Televison & Video
What video format does a curtis dvd1098b play by usb
I've had so many issues with trying to figure out what format this thing takes via the USB or SD card ports. I mean, for goodness sake's whatever you do don't give that information in the manual lol
After hours and hours I found that it not only depends on the format but the software. I still don't know exactly what the formats are that this things supports but I did finally find a program that produces avi files that play flawlessly on this thing. It's called "FairUse Wizard"
I just keep most everything to default as I'm clicking through the process. The things I did find that needed to be changed were:
1. Choose "Native Mode"
2. Check the "Use TV Display Mode" box
3. Choose 720x480 (others may work as well but this one always turns out with good quality and the file size is quite resonable)
Hope this saves somebody else the hours I spent pulling my hair out on this thing....
Jan 14, 2012 | Curtis DVD1098 Player
Hi I have tom-tom one XL (no sd card) model, it wont turn on,replaced the battery then ok next time nothing. But if I unplug the battery and connect again ok until I switch if off, I have to unplug battery...
Hi happyivan8 i know tomtoms answer to this problem is to plug it in to the computer for a few hours but thats not really a fix, just an added pain in the rear.
i have 2 of these and one worked good after i updated it but the other still has the same problem and will only start after i charge it via the usb cable or unplug and plug the battery back in.
try updating it through tomtom home but it may or mayneo solve the problem. if you have already tried the update and that didnt help, i dont know what else you can do other then use it for target practice like im going to.
you can get tomtom home HERE if you dont have it already!
Sep 27, 2009 | GPS
My creative zen player used to connect to pc now it dosent
my pc stopped detecting my zen. i tried and tried on all different pcs and nothing would pick it up. couldnt even get the battery sign on the zen. thought it was knacked. then one day i plugged it in again, got distracted and walked away. when i came back about two hours later, it was detected and charging. thought maybe that it was so flat that it had to charge a wee bit before it could display anything or the pc could find it. i dont know, dont know much about these things. just a thought
Apr 24, 2009 | Creative Labs ZEN V Plus MP3 Player
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive.
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
Make is jensen vm9311TS
I'll let you know if the codes are available..
Jun 03, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
No video
Hello I've just received an in car GPS system, and video/audio player from Japan. I live in Barbados, and I dont speak or understand japanese It is a Pioneer Carrozzeria AVIC-T1(CPN1800). I plugged my DVD player to it but ilke the previous writer, I am getting audio but not video. Can you give eny information concerning how I might remedy this.
Jan 25, 2007 | Pioneer AVX7300 7 in. Car Monitor
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
