Question about Nokia 9300 Handheld
Web problem. Whenever i try to access the web on my 9300, i get an error message saying ' Program closed : program: Web, Reason code: KERN-EXEC, Reason : 3'. What needs to be done to solve this problem?
  • 32 Answers
It happens if there is any important file miss from your phone do following : 1. Turn off phone and take out battery 2. Insert battery, and while it boots up press and hold Ctrl + Shift + F 3. After a few seconds you will be asked if you want to format or cancel I recommend having the device open when inserting the battery so you can press the combination quickly. Remember that this erases everything in the machine and it becomes like when you bought it. (I guess you know it, but mentioned it just in case).
Posted on Aug 14, 2007
Error code b500
Fixing 500 errors - general
This error can only be resolved by fixes to the Web server software. It is not a client-side problem. It is up to the operators of the Web server site to locate and analyse the logs which should give further information about the error.
Fixing 500 errors - CheckUpDown
Please contact us (email preferred) whenever you encounter 500 errors on your CheckUpDown account. We then have to liaise with your ISP and the vendor of the Web server software so they can trace the exact reason for the error. Correcting the error may require recoding program logic for the Web server software, which could take some time.
Sep 15, 2011 | Computers & Internet
Get Kern-Exec Reason 3 error when trying to scan for wifi connections on Sony Ericsson P1i
I also got the same error ... Did anyone found a solution for this
Anand
Sep 08, 2010 | Sony Ericsson P1i
Installed a new microsoft vx-3000 web cam When I go to start it a error message says it has to close because encountered a problem. Help please
Your firewall/ antivirus software is preventing the program to run, turn it off or allow to trust and re- install program
Mar 06, 2010 | Microsoft LifeCam VX-3000 Web Camera
I transferred a program into the calculator using the TI Connect software but when i go to the program in the calculator it says "undefined." I tried transferring the program from another calculator to...
A program, or an Application are both programs, but the former will be accessed through the program manager [PRGM] and the latter through application manager .[APPS] .If it is a program (in the context of the TI84Plus) you press [PRGM]. You see three menus [Exec [Edit] [New]. If there are any programs in the calculator, you should see them under [Exec] and under [Edit].
A. To RUN a program
  1. To run a program already in calculator, you select its name under the [EXEC] menu and press [ENTER]. If you get an error message "undefined" it is most certainly due a variable or parameter used in the program without its being defined first.
  2. This is programming error that must be corrected by editing the program.
  3. Usually you get a QUIT or GOTO in the error message.
  4. Press the number corresponding to GOTO and the cursor will be at the place where the error occurs
  5. If a program is archived (it has an asterisk in front of it name) you cannot run it. It must be unarchived first.
B. To edit a program
  1. To edit a program already in calculator, you select its name under the [EDIT] menu and press [ENTER].
  2. If you are allowed to edit it, you will be able to enter, delete and modify commands.
  3. To do so, you must know the programming language of the TI84Plus.
  4. If a program is archived (it has an asterisk in front of it name) you cannot edit. It must be unarchived first.
Hope it helps.
Thank you for rating this solution.
Dec 11, 2009 | Texas Instruments TI-84 Plus Silver...
Close the other video streaming application to start video
Your camera is already online. Double click the camera icon in the lower right task bar and it will work. That is the problem, the program is trying to run twice. Again, the camera is online and working and the access to it is in the task bar at the bottom. You, of course, can change these setting if you like.
Jun 21, 2009 | Dell Studio 1737 Laptop
Kern-exec 0 ERROR in Nokia E51
application closed MOSIA START THREAD KERN-EXEC3
I HAVE NOKIA E 51 MOBILE ND ERROR ON THIS MOBILE PLZ RPLY
Apr 10, 2009 | Nokia E51 Smartphone
Error
Hi i_m_blue,
You should try to use SEUS to flash your firmware.
If that won't work try to to do a master reset if you are quick enough wink.gif or uninstall this app that is causing this problem.
Otherwise you could try to contact your nearest service center to see if the can help you.
Thanks
Aug 27, 2008 | Sony Ericsson M600i Cellular Phone
Reason code KERN-EXEC reason no. 3
just to do a MR, if it dosnt work, try to browser C and D: drive and check the fonts, if similar fonts were installed, try to erase the other one on C:
Mar 13, 2008 | Sony Ericsson P910i Smartphone
P990i main menu open
if i open my main menu my phone show "application closed reason code kern-exec, reason number 3 " .what i can do .if u had any help plz help me.
Feb 08, 2008 | Sony Ericsson P990i Smartphone
!SisRegistryServer error
We have 2 problems :
1-Application
!SisRegistryServer
Reason Code
ucmp
Reason number
0
2-Application
Application installer
Reason Code
KERN-EXEC
Reason number
Nov 13, 2007 | Sony Ericsson P990i Cellular Phone
Nokia 9300 Handheld Logo
216 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
