Question about Samsung VC-5915V Bagged Canister Vacuum
Instructions manual I tried to clean the samsung 2000w digimax vacuum cleaner and now I have a problem to put back the filter and the bag. Is there any instructions manual that I can order?
  • trunigerd Nov 16, 2008
    Can I download an instructions manual?
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
b0sslady2001
  • 357 Answers
SOURCE: kirby shampoo instructions how to assemble shampooer
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
This is also a great place to order Kirby supplies!
Posted on Jun 22, 2008
reddevil6
  • 1673 Answers
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
jspahn
  • 105 Answers
SOURCE: Loss of suction
Have you ever cleaned the cyclone out. You should have a 5 year warranty. Dyson will probably replace your cyclone unit for you. Taking it apart isn't that hard You just need a long T-15 driver to get to the screws way up there. Many times the cyclones get clogged because someone either cleaned the whole thing with water or sucked up something wet.
Just check out this video I found on how to do it. Super easy, did mine both (I have a DC07 and DC17)
Posted on Jul 10, 2010
micromatikal
  • 2777 Answers
SOURCE: Instruction required for the removal of a full
Sure thing, the best thing to do is to have a look at the manual I have found here for you. The part you are looking for is on page 25 of the manual, complete with pictures and everything.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Here is the manual:
http://www.miele.co.uk/Resources/OperatingInstructions/S%205211_5781.pdf
Posted on Oct 15, 2010
Testimonial: "Thank you very much,we have missplaced our operating manual so this is just what we require,again our thanks"
How do I load the vacuum bag in the Electrolux power plus 2000w
If your Electrolux vacuum cleaner uses paper bags, the instructions should be printed on the bag.
Dec 03, 2014 | Electrolux Vacuums
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
I cleaned my filter and forgot how to put it back on, how?
Hi there! To return the air director back into the dirt cup, rotate 1/4 turn clockwise to lock into place. To replace the pleated filter. Return filter cartridge to base of cleaner. Click button on filter cover back into place to lock filter cartridge in base of cleaner. Hope this helps! I have also included a link to the instruction manual for reference if needed. Thanks! http://dirtdevil.com/file/956/
May 20, 2014 | Dirt Devil Easy Lite Quick Vacuum
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My samsung air track 2000W makes a really loud noise after 5 seconds of vacuuming. Sounds like its overheating but Ive cleaned all the filters so don't know wat is wrong!
I have the same vacuum. I cleaned the blue filter under the cylinder. Took it outside and hit it for about 2 mins to get much of the dust out, then washed it and left it to dry as it said in the instruction booklet. A copy of the instruction booklet is here: http://downloadcenter.samsung.com/content/UM/200903/20090304083344937/DJ68-00387A_EN_0.5.pdf
May 07, 2011 | Samsung Vacuums
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Dec 25, 2010 | Eureka Vacuums
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Will not start
try opening it up again and reclosing. Might be as simple as the cleaner is not lined up right. Check for bag misalignment. some cleaners have a lock-out mechanism that prevents the cleaner from starting if the lid and or bag are not in the proper alignment. If it is the filter compartment, same thing. Then, check a different outlet, check if your bag is full. if you were cleaning with the machine already prior to the checking of the back, maybe there is a clog or full bag as this would cause the vac to overheat and thus, the thermostat would not allow the vacuum to operate until it cools. If this is the case, change your bag, filter, and drop a penny through the hose(unattached from the vacuum and power nozzle) to check for blockage. Chances are, this is where your problem lies.
Jul 18, 2009 | Samsung Quiet Storm 9048R Bagged Canister...
Sanyo vacuum cleaner bag
We have the Sanyo Transfomax 3 in 1 vacuum and FINALLY found that one has to use a screwdriver at the edges of the "hand hold" just above the Sanyo name (between black and green parts), to pop open the cleaner in order to replace the bag or clean the filter.
What a miserable way to change a bag!
I know this is almost a year late...but I just found your request. Ta ta, Rita
Sep 16, 2007 | Sebo X4 Bagged Upright Vacuum
Samsung VC-5915V Bagged Canister Vacuum Logo
105 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
