Tv -jvc modele : av-g21t horizontal out put transistor burned after seconds
  • mohannadsale Nov 20, 2008
    thank u very mutch mr.jingjao
    Champion:
  • 252 Answers
Check the yoke or change the crystal number 503(blue/ orange)if still damage the Horzntal transistor , flyback is defected.
Posted on Nov 16, 2008
How to fix problem of jvc crt tv model av-21l31 power ok no video/audio no display with lines coming from flayback
Look at the horizontal output transistor then the fly back transformer.Check ALL the voltages coming from the power supply. One or more of them have to be missing for the audio and video to be gone at the same time.
Sep 24, 2014 | Televison & Video
Jvc model av32s33 wont turn on and has a blinking red light
check for a shorted regulator in the power supply section and bad horizontal output transistor.
Oct 02, 2012 | JVC AV-32S33 32" TV
My tv is JVC model # is AV-21MT35 the new technician needs the schematic diagram. my old technician lost the parts to be replaced one is for the horizontal out and the other one regulator...
You can use [BU508AF or C3886A OR D5702] as horizontal output. All of these transistors are equivalent to each other, and is commonly used with RCA TVs. But, if there is a fault with its Horizontal output Transformer, {LOT}, none of these transistors won't last long. They will heat up excessively, and will get shorted. Therefore, check whether the LOT has any trouble. Ask your technician. He will be sound enough how to check it. Mo multimeter check is possible with this component. His experience in service work will help him to troubleshoot this problem.
Aug 02, 2012 | RCA TruFlat 27F520T 27" TV
Power supply transistor transistor no. C4237 replaced 4 times. each replacement didnot sustain for a week. which transistor can i use instead.
I have worked to repair a few of these. When the transistor is burned, you most likely have a bad flyback transformer and bad picture tube. In this case you replaced this (transistor) component four times. This TV cannot be saved. Thanks for asking.
Oct 19, 2011 | JVC AV-24F704 24" TV
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
Where is the horizontal transistor
You can follow from fly back the B+ supply is directly connected to the horzontal out put transistor.
Feb 13, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC - AV-G21T
There are a number of very affordable places to download pdf files of the service manuals for that set.
servicemanuals.net
manualsparadise.com
user-service-manuals.com
Hope ya fix it!
Jan 06, 2008 | JVC AV-20120 TV
Model AV-32950 will not turn on. The power light is flashing and the relay RY921 is oscillating. I have replaced C926 1000uf/35v & no change. Any suggestions. Circuit daigrams????
did you check his horizontal transistor?what is the voltage of the b+ in flyback. but common causes of that model is the defective horizontal transistor.
Oct 18, 2007 | JVC AV-32950 TV
Jvc AV-36f802 not power up, automaticly shut down within 2 seconds
Hi, You may also want to check the Vertical IC. In some units I've worked on, failure or cold solder in the vertical IC triggers protection. Good luck and cheers.
Aug 15, 2007 | JVC AV-27820 27" TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
