Question about HP PSC 2210 All-In-One InkJet Printer
2210 - replace print cartridge
What page of the manual does it show where to replace a print cartridge please? I cant find it?
  • HP Master
  • 19,396 Answers
I put in a new cartridge (56) and now my alingment
after replacing the cairtage printer needs alignment it gives a test page when we put it face down on scannes it starts the alignment...
on alignment process it doesn;t found the colour bands so it shows the alignment failure..........
pls install the new colour cairtge the it will give u the printout
thanks....
Jul 08, 2010 | HP PSC 2210 All-In-One InkJet Printer
Every time i try to copy the screen says "press enter to align cartriges
Have you carried out a head alignment procedure, I would carry that out again
the online user manual is available from this link http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=79499&lang=en&
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge. Aligning the cartridges ensures high-quality output. To align the print cartridges when prompted:
  1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
  1. Press Setup.
  2. Press 5, then press 2.
  3. This selects Maintenance, and then selects Align Print Cartridges.
  4. A page of patterns is printed. The cartridges are aligned correctly.
  5. Recycle or discard the page.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP PSC 2210 All-In-One InkJet Printer
Keeps asking to aline print cartridges yet a printer test page prints okay.
This is normal when replacing the ink cartridges. You should be able to just do the aligment procedure to get rid of this message.
Oct 18, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP 6110 check cartridge error won't clear with new cartridges. Anyone know how to fix this?
You could try this way first as its a lot quicker and easier than the official steps from HP:
Just hold down the ENTER button and then press the MENU button. There will be a series of 3 fast, high beeps. Then everything resists and is a-okay. Both problems go away.
OR The HP way as listed below:
The ink cartridge-related error messages may occur due to one
of the following reasons:
* The ink cartridge does not make a proper electrical contact
* The cartridge is bad or wrong
* The cartridge is remanufactured or refilled
To resolve the error, follow these steps:
Step one: Check the print cartridges and clean the cartridge contacts
Even if the cartridge is new, follow these steps to clean the print
cartridge contacts. Print cartridges have a substance on the contacts
to keep them from corroding during storage that may cause poor
electrical contact between the print carriage and the print cartridge.
1. Verify that the product is turned on.
NOTE: If the HP product is not turned on, you will not be able to
remove the print cartridges.
2. Open the top cover or the cartridge access door in one of the
following ways:
* Pull the control panel forward and then lift the top section
toward the back.
* Open the access door on the left or right of the unit. This door
may be located under the scanner glass lid on some flatbed
products.
* On many flatbed products, you raise the front center section of
the unit to access the print cartridges.
* Raise the cartridge access door on the front of the product.
3. After the print carriage stops moving, unplug the power cord. You
must unplug the power cord to prevent the print carriage from
moving.
4. Remove both print cartridges.
5. Verify that the part number on the cartridge is the correct part
number for the all-in-one and that the carriage is not blocked
preventing the cartridges from moving. Visit the following HP Web
site for a cartridge compatibility chart.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpa00586
6. The electrical contacts of the print cartridge are coated with a
thin layer of grease to protect them from oxidation. This grease
may inhibit the electrical connection and should be removed. Using
a cotton swab or cloth lightly moistened with distilled, filtered,
or bottled water, clean the electrical contacts of the cartridge.
This usually occurs with a new ink cartridge, but may also occur
with an older cartridge.
NOTE: When an all-in-one is used frequently for black and white
printing but infrequently for color printing (for example,
an all-in-one that is used primarily as a fax machine), the
color cartridge will still eventually fail and need to be
replaced. The pins in the print carriage can cause dents
on the contact points of the color cartridge over time
(usually between six and twelve months).
7. Wipe the contacts with a dry, cotton cloth.
8. Reinsert the cartridges and lock them in place.
9. Close the top cover or access door and plug in the power cord.
10. If the error persists, repeat these steps. If further cleaning
fails to resolve the error, proceed to "Step two: Clean the
print carriage contacts" section.
Step two: Clean the print carriage contacts
Have the following materials available to clean the print carriage
contacts:
* Cotton swabs or any soft material that will not come apart or leave
fibers (for example, a scrap piece of clean cotton cloth).
* Distilled, filtered, or bottled water (tap water may contain
contaminants that can damage the print cartridges).
CAUTION: Be careful not to get ink on hands or clothing.
To clean the cartridge contacts inside the product, follow these steps:
1. Turn on the unit.
2. Open the top cover or cartridge access door.
5. Using a cotton swab or cloth lightly moistened with distilled,
filtered, or bottled water, clean the electrical contacts of the
print carriage.
6. On models equipped with locking latches, lower the latches.
7. Wait five to ten minutes for the contacts to dry and then plug in
the power cord. The unit will begin to reinitialize. Wait until
the process is complete before proceeding.
8. Reinsert the print cartridges when prompted and then close the top
cover or access door.
9. If the message recurs, replace the print cartridge indicated by the
message.
* If you are using refilled or remanufactured cartridges or non-HP
cartridges, replace them with new HP cartridges. HP cannot
guarantee that refilled or non-HP cartridges will function
correctly in HP products.
10. If the problem still exists, replace both print cartridges. Since
the cartridges are electronically connected through the printed
circuit board, the cartridge not indicated in the message might be
the causing the failure.
If the issue still persists, please click on the link below and install
the firmware update:
ftp://ftp.hp.com/pub/softlib/software3/COL4415/oj-14700-3/HpAiOFWUpdate2_2.exe
NOTE: Clicking the link may give an error indicating it is
invalid. If this occurs, copy the portion of the address
on the remaining line(s) and paste it at the end of the
address showing in your browser until the complete address
is displayed in the Address box.
1. Download the file "HpAiOFWUpdate2_2.exe" to a local hard drive. Make
note where (in which folder) the file gets copied.
2. The hp all-in-one software for the OfficeJet 6100 series must be
installed on your PC before installing this firmware update. The
OfficeJet 6100 series must also be connected to your PC and turned on
before proceeding.
3. Locate the file "HpAiOFWUpdate2_2" on your hard drive and
double-click the file to install the firmware update.
This should resolve the issue. If you need further assistance, please
reply to this message and we will be happy to assist you further.
You may receive an e-mail survey regarding your e-mail support
experience. We would appreciate your feedback.
Please visit our Owner Services Web site for details on keeping your HP
and Compaq products up and running.
http://www.hp.com/home/ownerservices
I hope this helps
Mike
Jun 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP 2210, screen says to press enter to aling cartridges
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer output is a blank page
hi,
* Please check with the ink level in the Catridge.
* Be sure that catridge nozzle is not dry or dirty.
* Check wheather ink nozzle is clogged/ damaged if so use rubbing alcohol to clean them.
* Try printing by replacing new catridge.
Thanks,
Appereciate to rate as "FixYa"
May 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP 2210 New Black Ink Cartridge print alignment page over & over.
unplug the printer while it is in ON state..it will reset all settings..^_^
May 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
Refill hp psc 2210 all in one
This item uses replaceable ink cartridges (56). You do not refill them.
You can find everything needed here:
HP PSC 2210 All in One Printer series
Jan 22, 2018 | HP PSC 2210 All-In-One InkJet Printer
Alignment / ink cartridge problem
You must replace both cartridges to perform a sucessful alignment.
Jan 12, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
