Question about Car Audio & Video
I just fit my mp3 but i don't know why after i take the key from the contact it deletes all the settings and the preset radio buttons.can u help me please
  • 24 Answers
Its not wired into a wire thats hot with the key off. it must be wired to a wire thats hot 24/7. if you have a test light that would really help..but just hook it into a hot wire and your stations and stuff will stay on there. good luck
Posted on Nov 16, 2008
How to I delete an occupied preset and enter another channel
My experience has always been to replace the current station preset with the new.
I recall two process:
  1. The first locate the new station that you want and tune the radio to the station. Press and hold the specific preset for several seconds to replace the old station with the new.
  2. Tune the radio to the new station and press the set button if so equipped and than press the preset button. In some radios they have group 1 and group 2. In that case press the set button once for set 1 and press it twice for set 2 and then press the preset button.
Hope this has helped?
Jan 12, 2016 | Cars & Trucks
How can i bypass the security code. bought car used and changed battery now can not unlock receiver
If this is not a factory fitted radio, then you need to contact the Radio manufacture of the head-unit and give them the serial number they will give you the code to unlock it.
If it is a factory fitted radio, then you will need the contact the Vehicle manufacture give them the VIN number of the vehicle and then they will give you the code for the radio.
Thanks
Jason
Jul 17, 2011 | Kenwood KDC-MP728 CD Player
Im trying to find out how to enter the radio code for a factory fitted stereo. A family member has just been given a renault 19 1994/1995. We have the code but, no user manual for stereo. Any help would...
PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don`t have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed
Press the Second Preset Button repeatedly for the 2nd digit to be displayed
Press the Third Preset Button repeatedly for 3rd digit to be displayed
Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code )
May 28, 2011 | Car Audio & Video
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
Radio
You could try pressing and holding the play button to set the preset.
To delete the preset, press the options button (ie. pwr off/option) and navigate down to the "Delete preset"
Mar 05, 2009 | Sony Walkman NWZ-S616F MP3 Player
Preset radio
In the settings menu, expand the FM radio menu and the second option is "Preset Delete". Push that and a list of all the presets comes up. Then select the ones you want to delete.
Sep 09, 2008 | Insignia Sport MP3 Player
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Sandisk e280 how do I get fm radio
Turn the wheel to FM Radio (There's a picture of a radio beside it). Press the center of the wheel or right arrow to select
FM Radio. To scan for a station use the left and right arrow keys (to the left & right of the wheel). To add/delete/view preset station list press the down button (below the wheel).
Dec 04, 2007 | SanDisk Sansa E280 MP3 Player
Pioneer DEH 435 CD player
Same as all Pioneers. With the car on or in ACC position press and hold SOURCE until the radio turns off. Press and hold FUNC to enter the menu. Use the four arrow keys to navigate and make changes.
Nov 30, 2007 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
