Question about Canon CLC 1110 Copier
Tonerproblem Hello! Our CLC 1110 didn't take blue toner.
  • 67 Answers
Can you explain further ,
Posted on Nov 27, 2008
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
• The developing assembly is not
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
Error Code: E071 0007
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
Canon CLC 4000 Error code E013-0002
Solution: the waste toner is have to get rid of that TONER.
Nov 04, 2009 | Canon CLC 4000 Copier
Canon clc 1110 gives E 803 0000 error. What could be the solution ?
the 24v is faulty
the dc power cut relay is faulty
the dc pcb is faulty the dc driver pcb faulty
during copy operation the cpu does not detect 24v out put for 5 seconds when the transfer unit lever switch,front cover switch,and delivery cover switch is closed
May 17, 2009 | Canon CLC 1110 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
E020 refers to incorrect operation of toner moter, jammed up toner hopper or motor stuffed.... If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. If the hopper is 1/2 full or less, the worm gear splits under normal use.
add toner only when the toner light is lit, right away, and replace toner motor.
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller.
Dec 02, 2007 | Canon CLC 1000 Color Copier
Canon CLC 1110 Copier Logo
old marine
old marine
