Question about HP Office Equipment & Supplies
Unit not printing - HP Office Equipment & Supplies
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to re-installe the driver
or replaced the usb
Posted on Nov 16, 2008
I have replaced the print heads, and instead of printing red, which I made, it is printing black
DEAR FRIENDS; PLS DO THIS FIRST STEP FIRST
How to print nozzle check pattern iPF6100/iPF610/iPF710/iPF8000S/iPF9000S/iPF800/iPF9100
  1. Load unused paper.
  2. Press the Menu button to display MAIN MENU .
  3. Press or to select Test Print , and then press the button.
  4. Press or to select Nozzle Check , and then press the button.
  5. Press or to select Yes , and then press the OK button.The printer goes online and prints a test pattern.
Second later print out result pls compare you result print with my attachment picture.
replaced-print-heads-instead-printing-5j51azquscxy1hu2enwrxd50-4-1.jpg let say if anything color no same like example red = black,yellow = yellow black , cyan = dark or magenta = green.
this means got dirty on site purge unit and printhead unit. you need to call canon technician done services for you because i can't teach you how to clean the purge unit and print head unit scared you will spoil this both unit.
Hope can help you ,TQVM..
Apr 13, 2016 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Printer has all full cartridges, not printing clearly
Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
Nov 20, 2015 | Office Equipment & Supplies
Kyocera 250ci making grinding noise
First you have to check the counters to see how many pages were printed or copyed. It may be a problem with some of the color drum units. At this model you need to change the units near to 100.000 A4 prints with 5% coverage. If the coverage is greater, then you'll need to change them sooner. There might be another cause for the sound, like the Transfer Belt Unit. This unit has a "waste toner path" that might be jamed. The unit is not able to get rid of this waste toner and some gears produce that noise. The transfer belt unit is working separatly for black prints and color print. You will have to remove the Transfer Belt Unit and clean the toner path with a vaccum cleaner.
Oct 23, 2014 | Kyocera Mita Office Equipment & Supplies
Oki C9650 not printing Yellow
remove the unit
open the cleaning lamp cover (front of unit)
turn O.P.C drum gear and check that toner is always applied to the developer roller
Sep 27, 2012 | Oki Printing Solutions C9650 Led Printer
With out printing numeres paper keeps coming out of port and stating paper jam
Try the Following Steps
1. Turn On the All-in-one unit
2. Disconnect the USB cable from the unit
3. Press and Hold OK and Cancel button on the unit while plugging in the power cord
4. This will perform a NVM reset
Once you have done this try Printing a self test page from the unit (Steps given below)
1. Press Setup button on the unit
2. Scroll to the option Print Reports
3. Select Print self test report
4. Check if it prints correctly.
May 17, 2009 | HP Officejet 5610 All-In-One InkJet...
Dell926
Clear Carrier JamThese are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges.
Regards
Chittaranjan
Dec 14, 2008 | Dell 926 All-In-One InkJet Printer
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
Nov 04, 2008 | Brother HL-2040 Laser Printer
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
