Question about Zanussi Dishwashers
Zanussi DE 4554 fills and starts to heat up, then stops heating before hot enough and starts to wash and will not stop.
  • 1462 Answers
SOURCE: the Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Posted on Mar 27, 2007
  • 22 Answers
SOURCE: zanussi de6855
most probably the pcb unit...had a few of these changed pcb and cured fault, not a job for a novice to be honest, think the parts is about £70-80 from memory.. ally
Posted on Jul 01, 2007
Falling Down
  • 67 Answers
SOURCE: problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Posted on Nov 30, 2007
SOURCE: I brought a Zanussi ZDT6053 integrated. - Fixed in position - buttons light up but does not fill in oor start.
Dearest FixYa,
Thanks ever so much for your prompt response and am ever so grateful for standing to support anyone in problem.
Fortunately, I have solved the problem.
Basically the problem was that the water supply tube would kink when unit was pushed back into its space under the kitchen top. And it was totally difficult to see that problem from he rear of the unit.
Last effort wasto monitor every thing as the unit was showly pushed bak under the kitchen top. This time it was discovered that the water tube happened to be seen clearly from underneath the unit as 'kinked'.
When straightened, the unit simply went 'full in motion, and hey presto it worked straignt away.
Thanks for your 'standing by' to support with an army and great team of 'experts behind you.
Sincere regards
Posted on Mar 30, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
Zanussi 1200 stopping on drain and not emptying showing error e61
Problem in heating phase. Could be heating element.
Dado
Sep 18, 2014 | Zanussi Washing Machines
Keeps on heating and no cool rinse put in new thermostat still heats and heats zanussi fle1416w
Sounds like you have it connected to hot water supply. This is a cold water fill only machine.
Jul 30, 2010 | Zanussi FLE1416W Front Load Washer
Matsui mf160 starts its wash cycle and timer stops
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
Jul 06, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
Hi there I have a Zanussi zdf121 dishwasher which is only doing a cold wash, not heating at all. Not sure if its hot fill but the hot water is fine elsewhere. Any ideas please Pete
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
Mar 02, 2009 | Zanussi 18 in. DA4342 Free-standing...
Zanussi zwf1211w
are the water supply taps fully on ? check that it is filling quick enough. let my know how you get on. also is it heating the water?
Feb 16, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi FLE1416W Front Loader
Most possible reasons that the door switch or timer unit is defective. The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. if you think that a user manual may help you more, it can be downloaded ($8.95) at url: http://www.download-manual.com/shop/Zanussi-FLE1416W-User-Manual-pr-8261.html
Jan 22, 2008 | Zanussi FLE1416W Front Load Washer
Zanussi da4342 dishwasher
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Jan 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Dishwasher
I have not heard of or seen this dishwasher but I do know on a lot of dishwashers if the water is not hot enough it will heat the water and the heating light will come on to let you know. On most models if the washer has to heat the water it will prolong the wash time. It may do this through out the wash and rince cycles. dont be surprized if your dishwasher runs 90 min or longer. This is normal for most all dishwashers now. I would read the owners guide and get to know whats normal for your unit.
Jul 12, 2007 | Zanussi 18 in. DE4744 Free-standing...
Dishwashers Logo
24 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
