i need some tips. my laptop fell and from that time on the screen turned black but if your going to look closely at the background, images are still present and the laptop is still functioning/running.
-   My laptop backlight works intermittently when I first turn it on. After it is warm, it seems okay, or if I fiddle with the cover button, it will come on. It is a pain in windows, because windows goes to sleep mode (windoze!). In GNU/Linux, I can just flick the button for a while and it comes on and stays.
-   hooya27
May 26, 2008
-   when i start the laptop i starts up fine but i can't see anything because the screen is all messed up
-   john delisio
Jan 07, 2008
-   the laptop fell and the screen is all messed up. it starts up fine its just i cant see anything. i've tried looking for the lcd number to get a new one but i cannot fing it.-   sasha123
Dec 15, 2007
-   My computer boots fine then in less than a minute, the screen goes dark as if a blank screensaver were activated. If you look closley, the images can be seen however very, very dark. Having this issue for a while, I've overcome it by pressing and releasing the sleep button (the black pin that is depressed when the lid is closed). That worked for a while however now nothing works. It was never dropped or damaged but on 2004 (when I had the same problem and it was under warranty) the FL inverter was replaced. It worked fine for 2 years then started to act up again. Should I be looking to replace it again? Also...is there a step by step blog to show me how? Thanks,
Seems that 1 something could have been knocked lose or 2 there is a break in the back of the screen that you can't see..It will have to be serviced either way....When it fell is the only way of knowing how much the prob could involve...hard fall from high or small fall from very low..crash to bump makes the diff of what the prob can be in all laptops...
I have a Compaq Armada 110 PIII that had a dark screen. Fiddling with the cover closed button would sometimes bring it back. If I turned it on and waited for a while, it would flicker on and stay. Finally I got so fed up with it I downloaded the (free on HP's site) repair manual for the 110. I took of the button/indicator cover (no screws, just pry it up) and below the cover button was a big hole, and a black rectangular switch. The switch had a plunger on it, but it was stuck down. I tried to pull the button up, but it just came completely off the board. Since it is a switch, and it is make to function, I reassembled the laptop, and voila! BACKLIGHT IS FINE, RIGHT FROM CMOS! So what if I don't have that button functioning - I don't have it MALfunctioning anymore!
There is another solution. Only if you cant afford to repair it. If you have a spare monitor laying about plug it in to the laptop believe me youll still get some more glorious hours from that laptop until you might drop the monitor WOOPS....
Was this helpful?
Yes
No
Solution #4
posted on Jul 22, 2007
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
Most likely the backlight is not working. Replacing backlight could solve the problem.
When your laptop screen is black but you can faintly see whats on the screen your backlight is not working.
It could not be working for a couple of reasons.
The power inverter could have come unplugged. This supplies the higher voltage necessary to power the screen.
The switch could be stuck. This is the switch that tells the laptop the lid is closed. I have seen on many models where the rubberized plunger that shuts off the LCD becomes jammed and it perfectly mimics a faulty inverter.
For a drop I would say check the lid switch first then the inverter.
the backlite of LCD displays are cold cathode flourescent lamp. I've open quite a lot of notebooks and LCD displays and here is what I can share: 1. The lamp itself is flexible (not glass).Only the LCD is glass. 2. the backlight is powered from an inverter with only 2 wires via a connector. 3. The HV inverter for the backligh tsupply have a small transformer with ferrite core.
The possiblities of damages are:
The connector supplxing power to the backlight turned loose, or the inverter transformer was detached from the PCB or the core is broken.
At least you can still use the notebook with external monitor in case the display is not fixed.
Please give me the URL for my new LG laptop manual. I would also like the page which tells me how to...
(More)
Please give me the URL for my new LG laptop manual. I would also like the page which tells me how to make desktop information larger than ''extra large.'' My laptop model is LGx12. LG 3G notebook PC X120-H.C7EKU I love my little laptop (notebook?) but my eyesight is not good enough to read the small print which is used constantly. I can make my document print use the font I want, but ''display'' just allows me a pick of 4 sizes, and the largest, ''extra large,'' is not large enough for me.
My Acer notebook will not turn on. I have it plugged in and the battery level (red or green) does...
(More)
My Acer notebook will not turn on. I have it plugged in and the battery level (red or green) does not come on.
my vista laptop has lost most of the sound. the mic ispermanently on, and when listenin to music or...
(More)
my vista laptop has lost most of the sound. the mic ispermanently on, and when listenin to music or any playback, it seems like there is only one channel working. the sound checks on the sound card seem to work OK. ANy ideas ? Other than get rid of this cr*p Vista ?
my acer 5610z laptop starts up but after it shows the acer load screen where you can access the...
(More)
MY ACER 5610Z LAPTOP STARTS UP BUT AFTER IT SHOWS THE ACER LOAD SCREEN WHERE YOU CAN ACCESS THE SETUP IT JUST GOES TO A BLACK SCREEN. I CAN GO INTO THE SETTING AND SEE NO PROBLEM. I HAVE ALSO TRIED TO RESTORE THE OPERATING SYSTEM BY PRESSING ALT AND F10 AT THE ACER SCREEN BUT ALL I GET IS A BLACK SCREEN AND A FLASHING CURSOR BUT NO PROMPTS
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
