Error code 09 for mitsubishi heavy industries paragon plus
Code fjashes in remote and i cannot read the model number no longer visible
  • 15 Answers
SOURCE: mitsubishi heavy industries a\c srk20zcx-s
Most of the time once every season so once a year same time you clean the filters. But being thats its the cheaper chinese made heavy industries and not the better quality japanese made mitsubishi electric i would say once every 3-6 months
Posted on Mar 16, 2008
notsomot
  • 67 Answers
SOURCE: Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Posted on Mar 05, 2009
  • 23 Answers
SOURCE: "FLT" blinking on Aircondition controller
I'm sure it is a reminder to clean the filter, is there a button to reset filter?
Posted on Jun 20, 2009
  • 7 Answers
SOURCE: Mitsubishi electric or Mitsubishi Heavy Industries
as an refrigeration engineer dealing whit them every day my advise is: mitsi heavy industry away much more reliable and better performing.
Posted on Jun 27, 2009
heatman101
  • 43501 Answers
SOURCE: I have 3 aircndition mitsubishi heavy industry one
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
I need a set of trippers for a Paragon timer Model number 4001-00. Where can I get them. Thank you. My name is Jim Vivone
Google search for X2772 tripper and some places may still have them.
Paragon is no longer making timers and parts except defrost timers.
Paragon 4001-00 120Volt timer uses X2772 tripper:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Paragon 4001-00 crossover to Intermatic is T101 120Volt timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring:
Paragon 4001-00 has terminals 1 2 3
T101 has terminals A 1 2
Paragon terminal 1 connects to Intermatic terminal 1
Paragon terminal 2 connects to Intermatic terminal 2
Paragon terminal 3 connects to Intermatic terminal A
Aug 03, 2011 | Hardware & Accessories
I need a tripper for my hot water heater timer... It is paragon model TC2 series A883-20. Can you advise?
I've read an expert here say that Paragon is out of *this* business now and that they are making defrost timers exclusively. I'm not so sure about this however. I would contact Paragon directly to learn if they have trippers available still for your timer.
If not - they may have suggestions for a direct replacement timer that would fit into your existing timer box. I have replaced several this way as it is preferable than removing cables, etc. when the exterior box itself is fine.
Mar 03, 2011 | Water Heaters
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I have a model 7005 outdoor timer ,brand new but no instructions to proceed with settings .Can you help me?
72d1511.jpgParagon 7000
Paragon 7005 is a heavy duty 7-day mechanical timer that can handle 4 loads. It is DPST. One of two wiring diagrams applies to this timer:
1d6e8ec.jpgThe question is the the timer clock motor is 120V or 240V?
36b7dc9.jpgParagon EC 7000 is a 7-day digital timer with 16 set points per week
Manual for EC7000
http://waterheatertimer.org/pdf/Paragon-EC7000-wire.pdf
Please re-post your questions as you start sorting out which timer you have.
Paragon is improving their site so there is less confusion over model numbers and functions. but information about the 7000 are still sketchy.
Oct 15, 2010 | Paragon Hardware & Accessories
Mar 03, 2009 | Mitsubishi Heating & Cooling
Jan 29, 2009 | Mitsubishi MS15TN Air Conditioner
Mitsubishi heavy industries a\c srk20zcx-s
Mar 06, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
462 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
