Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Black screen I turn on my television and it goes black after 30 minutes and it takes about 2 or 3 hours to come back
  • sportobob Dec 06, 2007
    My TV does the same thing. The screen turns off after a period of time and then will come back for a while and then go black again. What area should I be looking at for the solder connection that is heating up?
    Sergeant:
  • 308 Answers
Most likely suspect would be a bad solder connection. The connection heats up and becomes an "open" circuit like turning off a switch, and then as the set cools down the connection "makes" again allowing the set to come on. Parts should not be required as I consider this brand to be a "disposable" TV.
Posted on Dec 16, 2006
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
May 19, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Gateway shd 3010 LCD goes black
I have the same problem now!!! Did you ever find a solution?
Jan 02, 2009 | Gateway SHD-3010 30 in. HD-Ready LCD...
LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Jun 05, 2008 | LG 47LC7DF 47 in. LCD HDTV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Multi color snow
The most common problems with Panasonic's is the "DG" board. It usually is not the leat expensive module to replace and cannot be repaired it has to be replaced.
May 02, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Black screen and have sound
find problem here in threads,
Nov 15, 2006 | Mitsubishi VS-4543 45" TV
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
214 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
