Question about LG WM-2277HW Front Load Washer
Locked door with a OE problem code
My machine stops and gives me a problem code of OE and the door won't open, what is wrong?
Check the filter located at the bottom left hand corner. There is a door that you can open and pull out the filter.
Posted on Apr 03, 2007
  • Dawn W Oct 12, 2011
    Thank you just fixed my problem-and probably saved me hundred$ in having a repairman out!! Thank You
Can't open door
the two possibles are faulty door lock or water still in the machine. the error code should tell you which. go to AEG and their troubleshooting page will give you the codes.
Jan 30, 2013 | AEG Lavamat 72640 Front Load Washer
F61 code door won't open
Error E61 is generated when the door is locked but open.
Switch the appliance off.
After 5 minutes, use a thin screwdriver to push the lock to the right and then release it.
Restore the power, close the door and try the machine on a spin programme.
If you are still having trouble after this, let me know what actually happens when you try to use the appliance. The more detail you give the better.
Hope this helps
Let me know how it goes or if you need more help.
Dec 05, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
My maytag neptune MAH8700AWW shows an error code OE and the door is locked, how do I fix it?
Opening a locked door , click for a visual demo: Door locked#
It is possible that the actuator to the lock has failed and so is not releasing or there is a error on the control panel.
Jul 05, 2012 | Maytag Washing Machines
OE error code
Here's a link tot he LG site where the discuss the OE error and ways to resolve it...
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Jun 08, 2010 | LG WM1812C Front Load Washer
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
Error code oe
That's not OE, that's DE = Drain Error. Open the access door at the lower left on front of the machine. Use the small hose to drain the remaining water out of the machine, then open the large knob which is attached to the filter. If there is nothing in the filter, you may have an object which made it past the filter and is blocking the pump impeller, or the impeller may have come off the pump motor shaft, which would require pump motor replacement.
Oct 15, 2008 | LG WM-1485FHD Front Load Washer
My lg intellowasher wd1290 error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
759 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
