Question about Miele 24 in. Incognito G843SCVi Built-In Dishwasher
Cycle starts then stops and Intake/Drain light comes on
The unit drains when started, then starts to fill and stops, and the Intake drain light comes on, leaving 2 inches of water in the bottom. The drain tube is open and flows easily both ways. the many filters have been examined and found to be open and clean. All hoses are found to be open and unkinked. Any ideas? Thanks, Chris.
  • 2 more comments
  • spek Dec 25, 2007
    exactly same problem.!!
  • Frank Hingley Jan 01, 2008
    Have the same problem. I can't find the manual, do they mention what to do in this case(in the manual)?
  • svcaramia Jan 17, 2008
    Same problem. Dishwasher turns on so it looks like its working then stops and the intake/drain light comes on
  • DukeWeston Aug 20, 2008
    Same problem here. I have examined drain which appears clear, and intake filter which has a few holes blocked. To determine if that is the problem I will try running it once without that filter.
Hey All.
I had the same problem with my Miele g843, and i finally got to the root problem.
My machine would drain ok, and fill ok, but when it tried to start a cycle, it would do nothing. I could hear a relay occassionally clicking until it finally gave up and signalled the blinking red light of death.
I first checked the inlet filter, drain pump and drain pipe but I discovered no obstructions. So I started taking the dishwasher apart, and discovered that the main pump was seized! This may not be the source of YOUR problem, since it could be many things, but this worked for me. Here are the instructions to remove the pump and get it moving again:
Pull out the dishwasher and disconnect the power, water and drain lines.
Empty all water from the unit (disconnect drain line and let the water drain into a low profile container) you may have to elevate the unit and tilt it rearwards to get the remaining water out.
Remove the side panels of the machine.
Lay the unit on its side elevated about 2-4 inches above the ground (be careful you don't put direct pressure on any of the internal components when you support it)
Remove the 4 screws that hold the base panel to the frame of the machine.
You can now see the motor.
Disconnect the electrical connections to the motor and the pressure sensor.
Disengage the clamps that hold the rubber hoses to the motor and slide the hoses off the motor.
Unscrew the single bolt that holds the motor inplace on the back panel of the machine. Pry the rear panel out slightly to release the dowel pins and gently pull the motor towards you (pivoting on the inlet grommet). Once you have the motor out, you can try to manually turn it by rotating the impeller. If it is stiff, you could have the same problem mine had. Using silicon spray with a nozzle extension, spray the seal between the impeller housing and the motor and continue to spin the motor manually until it becomes free spinning. If this doesnt work for you, you may need a new motor ( i never priced one out but it cant be cheap ).
If you get stuck somewhere email me and i can send you pictures: vector006 at hotmail dot com
Cheers!
Posted on Mar 01, 2009
We had this problem where the drain light would flash and the machine would halt. Check the pan in the bottom of the machine-- you'll have to take off the bottom front panel. If there is any water in the pan the machine will shut down because of a water sensor switch in there. It's not enough to mop it out. you'll either have to let the pan air dry, or use a hair dryer to get all the moisture off the sensor. Ours locked up periodically until I replumbed the drain, disconnecting it from the garbage disposal.
Posted on Jan 25, 2008
I had the same problem with my G645 Plus: as you turn it on, the machine starts the drain cycle, fills the water and nothing more happens. I called the Miele technician and he confirmed that the motor of the main circulation pump was blocked (by soap become solid and who knows). So, the machine feels no pressure and thinks there is no water, and it stops. (The technician said to me that in older machines this failure stopped only the warming serpentine, and the cycle would continue with cold water, but that in the modern machine this failure makes the cycle stop).
The solution is to manually move a bit the axis of the motor, to free it.
Instead of disassembling the machine (exactly as suggested by Vector006), he tried first to move the motor by the inside, using a long, thin screwdriver he inserted into a small hole. This solved the problem in less than 10 seconds!! And without unplugging the inlet/drain conductures and the machine from its place!
To find the hole I'm talking about, you have to open the large filter at the bottom of the machine (under the place where you put the dishes). There you can see a large opening (from where the pump takes the water and makes it circulate) and, 2 or 3 cm over it, in the middle, a very small hole. That's it. Insert a thin (but LONG) screwdriver into it, sligthly inclined upwards, and gently press it until it reaches the impeller inside. The idea is to make it move just a bit.
If your model does not have this kind of hole, you have to follow Vector006's direction to access the motor axis.
I hope this helps!
Posted on Sep 09, 2009
  • Serial Keller
    Serial Keller Mar 20, 2012
    Yes, good suggestion regarding the access hole. I had cut up a coat hanger and did was able to move the impeller but it still felt stiff. Sure enough a month or so later it jammed up again. After the removal and the liberal silicone treatment, I haven't had the problem since.
  • Serial Keller
    Serial Keller Jan 01, 2014
    I should note that I am having this problem again on and off for the last year or so... might be time to remove the motor AGAIN!
If you have this problem (starting then stopping), the first thing I'd suggest is calling Miele. Their customer service person (in the US) was familiar with the problem. They instructed my wife to press a combination of buttons, which causes a selection of lights to display - from which the Miele rep can diagnose the fault.
Apparently, one cause of this fault is if there is a prolonged period when the washer is not used. This causes some component to dry out and become inflexible. In our case, the fault went away after we had been through the cycle of starting and draining by hand a few times. We didn't not have to pull the machine out or change any components and fortunately the problem has not returned
Sadly I don't have the button combination but if anyone finds out this would be a good place to post it.
Just a typical weekend, put the full dishwasher on, left the house and returned to find the dishwasher had gone on and then shut off with the basin part filled partly with water. I immediately looked for the manual which explains to clean the filter, then remove an L-shaped device inside the washer by the filter. Did that to no avail. Tried to remove the water filter at the water supply and since my shut off valve did not close properly, it was not an option to clean that without flooding my kitchen. So I happened to find this page and read about cleaning the drain hose by the food disposal (sink drain) , I removed the aviator clamp took the dishwasher drain hose off at the insinkerator food disposal, ran a screwdriver in the hole a few times to make sure it was clear on both the hose end and the drain end. Put it back together, turned washer on set it to #4 and it runs perfectly!! Another homeowner who got lucky with the remedies posted on this page. I am so amazed that it actually works perfectly like it did before. Mind you I shut the power off and on and ran it thru the initial cycle before it would malfunction. I did this about 10 times, nothing it was not going to work, until I removed the drain hose. Thank you so much for the great advice, times are tough and I really did not have it in my budget to call a high priced repair guy who'd be ready to gouge me because he thinks I have the money to buy a Miele in the first place. Truth is I spent the extra money on a Miele because I thought I would get extra years out of it, while giving value of a quality appliance to my home. Thanks again especially to the guy that said he went to Home Depot to buy a new $5 drain unit and was successful. (Can't find his post now and can't remember his name but if you scroll thru enough of these posts look for his step by step where he talks about the $5 dollar Home Depot part. Thanks Rob Z.
Posted on Jul 31, 2010
  • ROBBIE ZEE Jul 31, 2010
    This is Rob Z. I AM RE-POSTING AN ANSWER THAT FIXED MY MIELE INCOGNITO DISHWASHER IT WAS WRITTEN BY JOHN (HIVE BZZ) USER. John thanks a million!!!!!
    Hi All,
    Thx for all the tips. Combining your thoughts provided a solution for me.
    I had the same problem (with a ***** of thanksgiving dishes to do). Turn on,
    tries to drain, then that RED blinking "INTAKE/DRAIN" light, like you described.
    Spent hours, checking/clearing the (grey) drain hose (The other white hose is the water input to the dishwasher). Also took out metal filter, impeller cover, poked a coat hanger in both ways to/from the drain hose connection. All seemed clear. But still the same.
    But when I unhooked the grey drain hose from the air gap unit (that part going to the 4th hole in the sink surface), the dishwasher worked fine. So the air gap unit seemed plugged. The black hose from the garbage disposal to the air gap unit is free flowing (blew through it - yuch!). But the drain connection through the air gap unit was NOT as free flowing.
    Replaced it with a new air gap unit ($5.00 at Home depot).
    All works fine now. I feel I got lucky.
    Well this worked for me. Sorry for all of you who spent big bucks with no solution on those service guys that tried but did not help. I hope this helps some of you.
    John
I did what Vector006 did and its works for me too.
If you have not used your dishwasher on a regular basis you probably have the same problem, a stuck pump. Vector006 solution is the best way to solve this problem.
Also, if you call Meile they will send you a small wrench that you can use to try and free the pump. It it fails the only solution is to follow Vecor006.
Another fellow Chuckie1234 did the same thing and it worked for him as well.
Svcaramia
Posted on Mar 07, 2009
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
Miele dishwasher model G858 water will not circulate and the intake / drain code flashing? Does anyone know what needs to be replaced?
when you start a cycle, your machine should drain for 30 sec, fill with water, and then the circulation pump should come on. your water level should be up to the handle on the filter in the bottom. if you drain, and fill to the handle and then the intake drain error comes on, your circulation pump is stuck. if it does not fill to the handle, you may have a problem with the inlet valve.
Jun 02, 2012 | Miele 24 in. G858SCVi Plus Built-In...
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Hi i have an incognito built in dishwasher. it is
It is a PC board issue. Good thing you bought the warranty, hopefull it covers labor and not just parts.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Miele Dishwashers
Intake/Drain red light comes in and shuts down during wash cycle
I had the same problem. Switched to powder detergent instead of liquid and the problem was solved! Hope it works for you.
Nov 11, 2007 | Dishwashers
You will more that likely have a faulty waterproof inlet system
May 17, 2007 | Miele 24 in. Novotronic G851SC Plus...
Miele 24 in. Incognito G843SCVi Built-In Dishwasher Logo
1,584 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
