If you mean you arre unable to turn off the device, try removing the batteries for a while and putting them back in. If the camera still turns on automatically, it would mean that there is a loose contact.
You can try the temporary method - FIRMLY tap the camera against the palm of your hand. If it works, great, if not, your camera may require servicing.
Please see if u can gently lift the button upwards..sometimes the spring inside the button gets bad and leads to jamming..you may have to get it replaced by a techician.hope it helps!
Is it physically damaged or its just not working ?
You mean buttons are pressed? Try to press it gently, keep doing it until it pop out.
