Question about Acer AL1916W 19" LCD Monitor
Red tinting with the Acer LCD monitor AL1916
I have a slight reddish tint to my screen. If I try to auto configurate it, it goes back to normal for a few seconds and then back to the red. There was a recent thunderstorm and I didn't use the computer on that day.
  • 1 more comment
  • Anonymous Nov 27, 2008
    My monitor has a red tint to it that suddently appeared. What's up with that?
  • kthalyn001 Apr 05, 2009
    I did the same thing as drumscansing. But now the tint is back ! Can't somebody explain me what is happening? PS: I press autoconfig button..the monitor turns back to default colors for 1-2 sec ..but then the red tint is back !
    I did the same thing as drumscansing by mistake . For a while the monitor worked fine. But now the red tint is back ! When I press autoconfig ..the screen shows its default colors for 1-2 sec  then the red tint comes back ... I read a comment that was something like this 'its due to faulty IFB which cannot save colors''
Amazingly enough my monitor did the same thing and while looking for the serial number the problem got resolved. Since I don't know exactly how it got fixed I will tell you what I did. I turned the monitor off, removed the power cord from the unit, turned the surge protector off and back on, placed the monitor face down on my chair to read the serial number, reconnected the power cord and turned the unit back on. The problem was fixed. Go figure.
Posted on Nov 27, 2008
  • Acer Master
  • 5,568 Answers
Most later displays are provided with a driver written by the maker that will allow you to tweak color balance. You should find this by going to the Control Panel, then Display, then Settings, then Advanced. If you have Acer's driver installed (or Windows has had it in its library), there should be a color chart that will allow you to set the color to your satisfaction.
Posted on Nov 16, 2008
Hi:I have a Acer monitor,and on the bottom of the screen,where the task bar is and all along is discolored,The monitor isnt that old,2 years,maybe less.
What does the discoloration look like? Is it a pinkish or reddish color tint. This usually is the LCD inverterespecially if it is that slightly pink color and when it comes from the bottom of the screen. I could be wrong....
Thanks!!EJ Kudelka
Oct 11, 2011 | Computers & Internet
My Acer AL1717 Screen has turned Blue......I just want to know how to Turn it back to normal colour.....Anyone can Help??
hi,
reset your monitor color setting by the following setting
Press the menu button
Select Reset
press enter
this will reset the monitors color setting to factory default
ok
Jan 19, 2011 | Acer AL1717 17" LCD Monitor
I have an Acer AL1916 monitor and I turned it on like normal yesterday and it has now got a weird green tint all over.. I've gone into the settings of the monitor and played with the red, blue and green...
sounds like a cable problem, can you find another VGA cable to try, look at the cable ends carefully for bent pins.(they are easy to bend by accident) wiggle the blue VGA connector while its on, try both ends, I think when you push the button your pushing on the cable momentarily which causes the monitor to function properly, likely the connector on the back of the monitor. if this helps, please use the thumbs up for feedback. cheers
Aug 26, 2010 | Acer AL1916B 19" LCD Monitor
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
Normal screen is white background, but lately I am getting a blue tint that clears up sometimes and sometimes not. Please advise
Try hooking up another knowng working monitor to the computer and see if the blue tint comes back intermittently.
If it still comes up then you know your video card is the culprit. If the blue tint goes away then you know the original monitor is bad.
Aug 04, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Red tint on Viewsonic P930b
We do a lot of LCD monitor repairs and usually when you get the red tinted display it means the backlight tube is going out. This part is like a very small fluorescent tube just like in you office lamps. The tube is part of the display section and is very hard to replace. You can check the power supply first just to be sure. We have a dis-assembly/repair guide on our web site at: www.ccl-la.com/badcaps.htm If you find any bad capacitors you can change them and check but I would be it is the backlight tubes, if so just replace the monitor.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jul 20, 2009 | ViewSonic VX924 19" LCD Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
975 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
