Question about Dishwashers
The salt container is full of water after wash. Is this normal?DW60BI dishwasher.
    President:
  • 1,462 Answers
That is normal
Posted on Nov 16, 2008
Salt holder full of water
Hi Elizabeth
have had a dishwasher for many years and have found this to be a normal practice .... Hope this puts your mind at rest ????
Mar 20, 2016 | Dishwashers
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Bosch sgs45c02 salt container ful of water
the salt dispenser is always full of water, this is normal and you have no need to drain it. Just ensure you fill the dispenser with salt when the "Low Salt Light" is illuminated
Oct 03, 2012 | Bosch SGS45C02 Dishwasher
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
I cannot get my smeg dishwasher to programme the salt container light is on i have put salt in the dispenser but it is not full will that stop it from working
It is possible that water has gone into the salt container or the salt container sensor is faulty.
It might help find a possible cause if you proivde the full model number of dishwasher
Mar 13, 2011 | Dishwashers
Dishes not clean
hi friend,HOW TO GET THE BEST FROM YOUR DISHWASHER
Always follow the manufacturer's instructions and read the directions carefully on detergent, rinse aid and salt packaging.
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaning detergents are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
WHAT ELSE CAN I DO TO GET THE MOST FROM MY DISHWASHER?
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaners are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
LOADING
These items can be washed in a dishwasher, with the following guidelines:
Glassware - Any ordinary glassware and ovenware such as Pyrex. Do not wash lead crystal glasses unless they carry a "dishwasher safe" label.
Tableware - Most everyday crockery is safe. Bone china usually has under-glaze decoration and should be safe. Avoid antique or hand-painted and over-glaze decorated items. If in doubt, check with the manufacturer.
Cutlery - Stainless steel and silver cutlery are normally suitable for machine washing, but it pays to rinse off any acidic food before loading to prevent any corrosion and, if possible remove the cutlery immediately after the cycle, to avoid prolonged exposure in a humid atmosphere. Do not mix steel and silver cutlery in the same basket and wash bone or wooden-handled items by hand.
Plastics - Check whether they are dishwasher safe and do not place in the lower rack, where the heating element may affect the plastic during drying.
Pans - Stainless steel is ideal for dishwashers. aluminium can be washed in the machine, but may discolour during the rinsing. If in doubt, remove aluminium pans before the rinse cycle.
Always wash cast iron and wooden handled items by hand
WHY DOES MY MACHINE HAVE A WATER SOFTENER?
If the water is soft (i.e. does not contain calcium particles), the detergent will work more effectively and there will be less streaking on dishes. Hard water can also block the washer jets with lime scale and cause deposits on heating elements, which will reduce the cleaning efficiency, increase electricity costs and shorten the life of the machine. All dishwasher manufacturers (Bosch, Miele, Siemens) and detergent suppliers want you to get the best results from the machine - and soft water is one of the most important factors in achieving this. The way to ensure water remains soft is to regularly top up the reservoir with granular salt.
Three in one salt tablets do not activate the water softener.
HOW MUCH SALT DO I NEED TO ADD?
Your machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of ‘dishwasher salt’ use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
WHAT DETERGENT SHOULD I USE?
All modern dishwasher detergents are formulated to work specifically in dishwashers. On no occasion should ordinary washing up liquid be used, as it will cause excess foam, which can result in a leak. If it is accidentally used, sprinkle ordinary salt into the chamber to disperse the resulting suds. Then rinse away the excess salt before using.
There are 3 main types of dishwasher detergent - Powder, liquid or gel and tablets. Which one you choose will be down to personal preference, but most people find tablets very convenient, although using powder is usually more economical and liquids are less abrasive on more delicate items.
WHAT IS RINSE AID?
Rinse Aid is added to a special compartment in the machine and a very small amount is released during the final hot rinse cycle, to reduce the formation of water droplets on crockery etc and so ensures that the water dries away properly and evenly to avoid leaving smears.
Dual action detergent usually contains rinse aid, which is released at a different rate to the cleaning agent and so helps reduce smearing etc without the need to add separate rinse aid. Some 3-in-1 tablets contain an ingredient, which has a 'salt action', which also helps to improve cleaning, but NOTE this is not a substitute for adding salt to the water softener.
The salt action takes place in the cleaning chamber of the machine, but does not actually replenish the water softener. Research has shown that whilst 3-in-1 detergents do clean dishes effectively, their performance is improved by adding salt to the water softener reservoir.
As the performance of machines can vary, as can local water conditions, it is always best to follow your manufacturer’s advice. Some manufacturers advise that if you have unsatisfactory cleaning performance eg white powder residue, poor drying or dirty dishes, then you should return to using three separate products ie detergent, rinse aid and granular salt. Be aware that if you have not been filling the salt reservoir and relying on the salt in 3-in-1 tablets, then it may take a few cycles to re-generate the softener.
hope this helps u
please rate me..................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Dishwashers
Dishwasher - water softener not working
Make sure your water temperature is at least 120 degrees .Make sure your heater element is working and last of all ,Rinse Aid is the 2nd most important after water temp.
May 26, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwashers Logo
234 people viewed this question
Top Dishwashers Experts
