Every time the immersion heater comes on, the circuit breaker in the consumer unit starts buzzing loudly. Is the breaker faulty?
  • 31 Answers
Are you sure its a breaker and not the contactor stuck ,when you call for the heat to come on the contactor pulls in and over time and wear and tear the contacts get stuck
Posted on Nov 16, 2008
Samsung dishwasher makes a loud buzzing sound when the water is filling. It pulses a couple times to start then is constant. It pulses again right before the wash cycle. Comes from the bottom left.
This is common. The noise is coming from the water pump. If it bothers you, you can try UNPLUGGING the washer or turn off the Circuit breaker first. Then you can remove the bottom kickplate on the front of the washer and clean around the pump. If there is a water filter scree, clean it out. Make sure there is nothing rubbing against the pump which could cause a buzz. Tighten all fittings and screws to eliminate vibration noise.
Aug 30, 2015 | Samsung Dishwashers
Main fuse tripping when...
That could mean that there's a wiring fault (short-circuit). Unplug the unit from the wall socket and see if the breaker closes again.
If so: check the building wiring (get a certified electrician!)
If not: the heater wire is probably the cause. If it's a new unit, you should return it to the store for exchange. If you have no more warranty, have someone with electrotechnician skills replace the wire.
Dec 15, 2013 | Computers & Internet
Hotub clicks and then makes buzzing noise when turned on.
does it blow a breaker? check to see what is going on by unplugging all the pumps, blowers lights and anything else plugged into the circuit board (heater too)
turn the breaker on once everything is unplugged and then proceed to turn the spa off, plug one item back in and turn the breaker back on.
Do this until you find the buzzing....
You may actually have a back relay on the circuit board causing the buzzing by not latching in when the pump or something is trying to come on.
Rod
Aug 23, 2011 | Home
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
No power, tripping circuit breaker, loud pop inside when wash cycle starts.
Sounds like the main wash pump has burnt out are there any leaks under unit.It could also be the heater.but the loud pop sounds more like the wash pump.
Hope this helped.
May 11, 2010 | Tricity Bendix 24 in. DH104 Free-Standing...
Air handler is running but outside unit fan is not running. Just a buzzing noise.
The buzzing if it is real loud is a very wore out contactor and could be the cause of your unit not running. Check your circuit breaker. you'll likely need service and have the unit cleaned for best performance. Good luck Tom
Jun 28, 2009 | Goodman CPLE24-1 Air Conditioner
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Apr 13, 2009 | Whirlpool MH7155XM Microwave Oven
Loud buzzing after heating up
the buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Oct 13, 2007 | Marvin Quartz Radiant Heater
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
