Question about Panasonic Audio Players & Recorders
My panasonic SA-PM17 5 cd changer door cannot open nor swap cd 1-5.......only hear motor servo noise like gears out off catch. cassette and radio and auxiliary input and amp work normal. open up box and cleaned ribbon contacts and reset cd tray side panel wormgear after retrieving the 5 CDs stuck inside. Q:any other gears within the central 5 tray plastic unit that needs resetting?
  • 6 Answers
SOURCE: Denon UD-M50 cd changer. Need help extracting drawer for home repair!
Hi KathyKate
If you are still having the same problem with your denon UD-M50 I might be able to help. I have fixed a number of them in the past and have the necessary maintenance manual and knowledge of a company that can supply spare parts. Disassembly looks very complex, especially when the problem is with the carousel but once you have an understanding of the mechanism it's not that difficult. Care should be taken when manually removing and reloading the disc trays as damage can result to the 'Teeth' alongside each. Spare trays are available. All my repairs involved the removal of the carousel mechanism in order to align the trays. I can copy the relevant sections of the manual dealing with the re-alignment which is critical but again if followed exactly you should have no trouble. If you respond with an Email address, I will be only too pleased to forward you the schematics etc.
Regards Ibbotsnm
Posted on Dec 15, 2007
  • 319 Answers
SOURCE: jammed CD tray system
You may have a disk that fell out of tray onto lower mechanism. Be careful when disassembling mechanism as they have timing gears that are positioned to perform certain functions
Posted on May 07, 2008
  • 4 Answers
SOURCE: 2004 acura tsx 6cd changer jammed
Posted on Jul 15, 2008
  • 4234 Answers
SOURCE: Panasonic SC-PM41. The multi changer jammed
This can be fixed, but the method of doing this involves the rebuilding of the CD loading mechanism. This should be done by a Panasonic authorized service center. There is a specific way to build and align this mechanism. There was also an engineering modification to this mechanism to prevent problems as well.
Posted on Aug 22, 2008
  • 4 Answers
SOURCE: Jeep RDS CD Problem
Did you change the battery ? If so try disonnecting and reconnecting the CD changer.
Posted on Dec 28, 2008
Error f61 on my panasonic sa-ak330
The f61 code is believed to be an amplifier circuit fault, but in reality it more often than not turns out to be a problem with a jammed up motor elsewhere(fan, cd changer motor, cassette motor). For me it was a jammed up cd changer. I simply disconnected the control for the changer and operation resumed as normal.
Mar 30, 2013 | Audio Players & Recorders
DVD changer is jammed on my Panasonic Sa-pt770 Receiver
if you have 2 tiny screw drivers, if not, the tips of a butter knife might be skinny enough, you can try to insert them a wee bit into both sides of the tray and pry outward, carefully of course, and unjam the tray
Mar 09, 2013 | Panasonic Sa-pt770 Receiver Only For...
Malfunctioning CD, Cassette, Radio stereo
With all due respect, it is not the sort of fault a novice can fix with any competence. It has power supply and system issues.
Jul 12, 2017 | Panasonic Sa-pm27 Shelf System 5 Cd...
I have a Panasonic SA-PT660. It is just over a year old...and I get the 5 Disk changer to open. I turn the unit on and it just clicks (sounds like machine gun) going off. It says Disk Changer Error....
Hi there
Q: Did you push the CD Door by force?
If yes ...
1: you have misplaced the mechanical wheels ..
or broke some thing.
2: Or the second possibility is that the Driving motor rubber is broken
the answer is to service it.
Good Luck
Hope this helps
Nov 19, 2017 | Panasonic SC-PT660 Theater System
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
How do i return to my radio from my cassette? The eject button is broken.
Open it, try manual eject, if not look for the switch that monitor between cassette and radio mode, you can do manual connection or switch it manually.get it?
Aug 30, 2009 | Pyle Double Din AM/FM Cassette & CD Player...
I have a 2000 beetle with fixing in the boot for cd changer...will any changer do, not sure what i should be looking for! Thanks
Likely have a Monsoon radio system in your 2000 Beetle. The CD changer is controlled by your radio, and not any CD changer will connect to the outlet in your trunk. You can either find a CD changer on eBay (or elsewhere, or swap out your radio for a radio from a newer VW Beetle that has a CD player installed instead of the cassette. Can also find those on eBay.
Jun 10, 2009 | 2000 Volkswagen Beetle
Cassette adapter and MP3 not working
Usually a dirty tape head. I recommend adding a 3.5 jack to your radio through an fm modulator.
Apr 24, 2009 | Sanyo FXCD-500 RB CD/Cassette Receiver...
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
513 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
