Question about Hotpoint WMA50 Front Load Washer
I need to change the door seal on a Hotpoint Aquarius WMA50
Can this be done by a novice - if so how?
Any special tools required?
Advice appreciated.
Kev.
  • 135 Answers
Basic diy tools should be ok. Take out lid screws behind plastic caps on edge(will be stars but small flat will do it).Lift front of lid and push back to remove.Remove kick plate and take out screws behind it.Remove band holding front end of seal and detach seal from rim of opening. Remove screws holding door lock and push lock through. Remove soap drawer & take out screws behind it.Carefully bring panel forward & slide to right to remove(Take care here with board &wiring)Remove screws holding front panel & lift front panel & remove it.Remove band from seal and your there.Note locating slot on seal. If possible get an extra pair of hands to hold panel with board to avoid damage.
Posted on Nov 16, 2008
My Hotpoint wma50 has developed a terrible smell inside the drum area.There doesn't look like anything is trapped inside. Any advice would be much appreciated
Posted on Aug 26, 2009
The machine makes excessive noise when spinning and the drum feels to have some movement. I think that the bearing needs to be replaced. The machine is a 6 kg Not tried to fix it yet. Need advice on how...
quite a hard job if you never done this work before.....Depending on model bearings can be on its own kit or you will need HALF DRUM complete with prefitted bearings cost of this is around £75 ...plus labour at around 2 hrs.....If its under 5 yrs old Hotpont give a 5 yr warranty call charge is around £100,although this is all you would pay as the Parts are under warranty..Hope this helps.
Jan 06, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
My hotpoint washing machine (model wma50) will not start due to the door lock light flashing yet the door is closed
common problem on these machine's, you need a new door handle which comes as a full assembley with spring and all attached.
open the door, using star screw driver remove top and bottom screws along with two near the catch.
the doo wil split enough to remove old handle and fit new 1.
Oct 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Where is the water filter kept on the hotpoint aquarius wma50
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum, filter is located inside the hose.
Sep 19, 2010 | Hotpoint WMA50 Front Load Washer
Hi, i have a hotpoint aquarius 6kg wma50, my
Have you checked for blockage in the pump. Or the have been some problems with a ball that sits in the hose between pump and the drum. This can block the water. Check this berfore purchase new pump.
Jul 26, 2009 | Washing Machines
Hotpoint WF645 : Do I Need special tool to clamp
not worked on this model.but hotpoint are usually eaSY. no special tools.but i found it easier to take the front of the machine and work at it that way about 1 hour
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wma50
The motor does not have provision for belt adjostment, it is self tensioning
To gain access to the brushes, you need to remove the motor from the washer.
Remove rear panel, remove belt, unplug motor lead, taking note which way the plug goes,undo screws securing motor, and lever motor back with a screw driver, remove motor and change brushes.
Feb 12, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA50
you can buy a replacement from hotpoint.
Jul 28, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
408 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
