Question about Gateway 7330GZ Notebook
Backlight doesn't work. How much to replace? Can I fix if novice
Is it expensive to fix and can I do it myself if a novice?
  • aee391 Nov 16, 2008
    I have a Gateway MX3228 laptop with a similar problem. The backlight works sporadically. What can I do?
    Scholar:
  • 149 Answers
Backlights are not generally expensive but I wouldn't suggest you repair it yourself unless you've opened up pc's before....you'll need a service repair manual to do it yourself as, at the very least, you'll have to remove the screen bezel (usually 4 screws) and then detach the screen from the hinges (again usually 4 screws).
I would suggest getting a couple of quotes from repair centres.
As far as backlight goes it either works or doesn't (like a light bulb) sporadic use usually means a bad connection rather than a blown light but it would still need to be opened up to check the connections...again needing a service manual and a technical person
Posted on Dec 05, 2008
No image on my laptop screen only on an external monitor
LCD panel,cable or inverter are faulty.Inverter and CCFL backlight check is shining a torchlight across the screen to see if there is any image in the screen.This doesn't isolate either problem but can provide testing options.If it is an LED panel no option but to replace if backlight issue.If you don't have spare parts to test with you are stuck though.If you are a novice in repair it could cause more problems by damaging/breaking parts in attempts to fix.
Aug 29, 2014 | Computers & Internet
Samsung LN46C630K1F No Backlight, Replaced Board, Still Doesn't Work
because you see a picture with a flashlight it means your power supply is fine. you probably need to replace the backlight inverter board if you haven't done so yet.if that doesn't fix it then you have a bad panel, and at that point it will be too expensive to replace. Good luck!
Mar 04, 2014 | Televison & Video
The microwave unit on my Thermadore CMT231 (integrated microwave convection oven) has suddenly stopped functioning. I suspect a fuse has blown. Is this a self-serviceable part? I am a complete novice, but...
No to novice work! get yourself or your family killed (although you might do Darwins' work for him.....)
Yes to fuse, check the HV fuse and try replacing it. if it blows again you have a serious fault and need a micro tech.
PS expensive :-(
Oct 14, 2013 | Thermador Ovens
Tv doesnt turn on...just clicks
the relay is clicking on. it mave have bad contacts internally. this controls the power supply for the audio and video circuits. you may just have a blown power supply fuse. since you are a novice. recommend service by tech should get an estimate 1st. shouldn't be too expensive
Sep 20, 2009 | Televison & Video
I have a Insignia NS-LCD26-09 that the backlight appears to have failed. I can see the display but is very dark. One day it worked and the next day it did not. Is it worth fixing?
Check eBay for a new backlight bulb. If you are willing to do the work to replace it, it is up to you how much it is worth. (I am poor so would fix it myself)
Sep 08, 2009 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Dreaded 4 blinks
Tries take out ur video connection to ur board. See if u get the power to the to the tv.If u still getting power but blinking ur power board it dead.U just hope not ur backlight,if it is u in major trouble very expense only professional have the equipment to replace the backlight must have recalabration gun to fix this prob.Power board prob. only $300 u do the the labors,if tv tech. do it well cost u $575 but u have 1 year waranty.U who know??
Aug 24, 2009 | Televison & Video
No backlighting on keyboard
if replacing the keyboard did no resolve, and backlight is enabled in the bios, then palmrest replacement is next
Aug 10, 2009 | Dell Studio 1737 Laptop
Screen dark, but intermittant. Is it backlight, inverter or other
I always start with replacing the inverter since it's much much easier and is usually the source of these problems.
If that doesn't work you could replace the backlight ( not fun or easy for a novice) or replace the entire lcd.
Best of luck!
Jun 13, 2009 | IBM Lenovo ThinkPad X40 Notebook
Long delay before comes on
Honestly, this does not have any real affect on the future performance or operation of the TV so it may not be worth investing in unless you are very bothered by it.
The backlight is something that is not easily repaired by a novice and extremely expensive to repair in general(more or equal to the cost of a new TV).
Good news is that these manuals are written by people who don't have an exact concept of how the words are interpretted. For example, the manual says "the backlight is failing" which means the backlight should be replaced. I am sure it was meant to say "the backlight components are failing" which may mean only a board or small compenent that affects the backlight needs replacing. This may be much cheaper.
May 22, 2009 | Philips 50PFP5332D 50 in. Plasma...
Screen broken
If there is definitely a cracked display then only solution is to replace the LCD panel- this is NOT for the novice having said that I was once a novice..I guess I still am:) the LCD panel as its quite expensive for joe ordinary to buy you may have luck locating a used one but be careful out there..its a minefield
Dec 16, 2007 | LG 42LC2D 42 in. LCD HDTV
Gateway 7330GZ Notebook Logo
76 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
